i tested my motor with a 12V battery and sure enough it works. previously i disconnected the diverter and the rear wiper hose and ran a straight connector to the front wiper hose and it did not work.
then i blew through the HOSE that runs from the diverter to the tank and i could hear bubbles.
now that i can hear the motor running out of the vehicle i tried blowing through the other hoses and here are the results:
1. hose to the tank works (actually there appears to be a one way valve in the hose at the tank so you can only - well i don’t know but eheee appears to be some kind of one way valve in this hose).
2. hose to the rear wiper does not seem to be clear.
>3. the circuit to the NOZZLES does NOT seem to be clear. if i blow into the hose that connects to the diverter you cannot do this. i CAN blow through the hose if i disconnect it from the white ninety degree connector inside the hood but if it is connected to the ninety degree connector it seems blocked.
i /have/ actually dropped the sprayers in an ultrasonic cleanser as long as i hade them out.
any ideas on where to go from here?
tie some string to the hose under the hood and pull s*** out after disconnecting the sprayers and see if one of the hoses are blocked?
only other thing i can think of is that there is a fuse that blew or that the mechanism at the stalk has corroded contacts or something? or a wire in the harness is busted?
thanks for any help with this. (advance apologies if you saw this cross posted elsewhere).
