- Thread starter
- #21
Unfortunately not much without upgrading the birf too.
Ok...I’ve got what I bet is a stupid question and hope you can help me out.
Was given a set of Aisin hubs in the typical short body style. Have zero clue what they were off of. I rebuilt them and went to install them on what i believe is a ‘77 40 series axle with 60 series knuckle/disc/birfs...which were rebuilt by me (thanks for the parts!). Dang hubs won’t fit over the end of the birf. Birf end is larger diameter then the inside diameter of the Aisin hub gear.
Do I have IFS hubs? Can I swap out the guts of the hubs and use the bodies I have? If yes, do you guys sell the parts?
Appreciate the help/education!
Edit - I need this right? HUB301507-1-KIT
Not for a cruiser, but given the discussion about internal differences, seems relevant. So the HUBFHT008 are listed for 79-90 LC/PU/4R. We are picking up a 90 v6 PU this weekend and somebody put a set or WARN hubs on it and I'm thinking that wrong must be righted. Are these the proper hubs for a PU? Also, do they come with gaskets or would those need to be added? Thanks
Kurt,
I have a 79 PU with the ASCO hubs. One needs some new internals, and I was wondering which, if any, of the AISIN hubs i could get to do a dial swap on it so the truck says saying ASCO on both sides?
Yep, you hooked me up, i ordered the locking hub and the front axle service kit, so all is good! Thanks!
Maybe an old thread but hoping someone can help me identify these hubs. I picked them up hoping they'd fit my 2nd Gen 4Runner as they have a 26/7 spline count but they are way too small and have a different design than most aisins I've seen. They only use one set of bolts that run from the dial/cover through the body and into the hub. They are also way smaller than a toyota hub, even the axle diameter is smaller. Any ideas?
Thanks cruiseroutfit. Still wish I could find another example of this style. Even the Mitsu's Iooked up have the 2 separate sets of bolts. Interesting.Looks like the older IFS Mitsubishi to me. There is very little carryover from one brand to the next, they all have different spline counts, profiles or depths. I can check at the shop and see if we have more resolute application data on that one.
