Single link bars in general do not work properly and end up breaking because by design, they can not deal with articulation. They work great in a "straight up and down" application. But when articulation comes into play, they quickly reach their mechanical limits.
Hey Georg, I'm interested in knowing more here on where the articulation will break a single link type bar? For the ones that you've seen break, what sort of mounts were they using at each end? Did they allow for twist to follow the axle?
Obviously, with a single link bar, it needs to be able to freely follow the axle as it articulates. If not, it will surely break.
This is actually the type I've been using for years. I've also installed them on several other FJ40's and as far as I know, no breakage, at least none reported to me. They are not faultless in design and actually force small pinion angle changes as the axle moves up and down, but they also help limit the axle rotation which causes the ujoint and pinion breakage. But, a single bar relies on the leaf spring to complete the triangulation and therefore it is a weakness in the design, but they definitely work much better than no bar at all.
If you really like the skinny pedal then the single bar type is probably not a good chioce for you as you are likely to still twist up the springs over time. Very soft springs will also tend to make this type less effective since again, the spring is part of the anti-rotation equation.
Basically, I've had good luck with them and will continue to use them. They are simple to make, cheap, and they don't require massive wall tube.
Slso, I believe that there is less "forced" rotation induced with suspention travel with the single bar vs. the triangle bar type. But again, if you have a heavy foot, I've vote for the triangle type. The Single tube type works well with my driving style...the skinny pedal scares me.
thing! Grabbed a radius arm from one of those 80 series station wagon thingies, flipped it upside down and stick it in. Works great.
