leaf me alone
Don's design has the T-bar above the front shackle and the drawing in post #1 shows the bar below.Pics of the bar in the same 40.
Ed, stop trying to re-invent the wheel.
Is one design better than the other? I have seen it done both ways.
Cheers,
Brian
Cheers,
Brian
I'm interested in this too as I'll be building one soon.
the bolts which attach to the axle housing my weak link. They sheared once when I slid backwards down a really steep, slippery snow covered trail, and stopped suddenly. It was what I wanted, replaced the bolts, no damage to anything else.
Fast Eddy likes the shackle pointing straight back at the axle so the bar can tip upwards or downwards.
If the shackle is laying down horizontal then how could it possibly keep the pinion from rotating up?!![]()
Cheers,
Brian
It will still rotate up a little, but not beyond the limits of the u-joint. It makes the whole system very flexible, as it should be. The bar helps the springs keep the pinion from rotating up. It doesn't have to keep it perfectly rigid. 3" at the front of the bar equates to a change in pinion angle of about 4 degrees.
I got hurt in '06 and ended up selling it along with all the spare parts/new tub/axles to a guy in Indiana who's rebuilding it far as I know .
Sarge
if you put a short tower on axle and again cycle for wrap, the tower moves front to back, while the axle moves up and down,totally separating the forces
now we can focus on keeping that tower upright.
A single link, horizontally forward to a point near the dshaft pivot will keep the top of tower vertical, yet allow the axle to move up and easily
I merely welded a HD shackle on my skidplate
the antiwrap bar will dictate the angle of the pinion, it changes slightly while cycling, but nowhere near as much as it could without, and always is within working angles
one of these days I will build a link setup.....
that little buggy is inspiring
yours is cool too georg
when is the special on for the atlas?![]()
