Words defined for us Newbies ...
Advance, NC
I'm a Newbie and have only owned my LX470 for a few months.
I've picked up a lot of the terminology over my time on this Form
but some things I don't know what the topic is all about.
What is Slee?
What is Hundy?
What is locker - as on 1998-1999 LX/LC?
Slee Off Road. Great place to spend all of your money
xxx
Locker, as in locking differential.
What is Slee?
What is Hundy?
I am a complete noob also but I know what these mean.
Hundy = Hundred (100 series Land cruiser/LX 98-07)
Slee is a shop in Colorado that makes and sells offroad products for these trucks
Locker is a differential locker (locks both wheels so no free spin) that came on the early model LC and never came on the LX in the US.
Here are a few acronyms for you......
A-TRAC active traction control
A/T automatic transmission
ABS antilock braking system
APPS accelerator pedal position sensor
AT automatic transmission
BAT battery
CAT catalytic converter
CDL center differential lock
CEL check engine light
CV constant velocity joint
DIY do it yourself
DRL daytime running lights
DS driver side
DTC diagnostic trouble code
ECU engine control unit
FSB front sway bar
FSM factory service manual
4WD four-wheel drive
HID high intensity discharge
LCA lower control arm
LSD limited slip differential
MAF mass airflow sensor
MIL multifunction indicator lamp
MOD modification
MPG miles per gallon
MY model year
O2 oxygen sensor
OBDII on board diagnostics II
OE original equipment
OEM original equipment manufacturer
OME Old Man Emu
OP original poster
PO previous poster
PPI pre-purchase inspection
PS passenger side
PS power steering
RPM revolutions per minute
RSB rear sway bar
RSCA rollover sensing curtain airbag
RTH real time help
RTP real time problem
SRS supplemental restraint system
T-Bar torsion bar
TB throttle body
TB timing belt
TCU transmission control unit
TLCA Toyota Land Cruiser Association
TPMS tire pressure monitoring system
TPS throttle position sensor
TRAC traction control
TSB technical service bulletin
UCA upper control arm
VSC vehicle stability control
VTC vehicle traction control
WOT wide open throttle
I had to google to find out what VGRS was when reading this Forum - Variable Gear Ratio Steering.
I looked in my 2002 LX470 owners manual for VGRS but it only mentioned something
about speed proportional power steering. Apparently VGRS was introduced in 2002.
I assume this is all correct.
Holy acronym list @Sandroad - that should be in the FAQ!
BAT battery
DIY do it yourself
DS driver side
FSB front sway bar
MOD modification
MY model year
O2 oxygen sensor
OME Old Man Emu
OP original poster
PO previous poster
PS passenger side
PS power steering
RSB rear sway bar
RTH real time help
T-Bar torsion bar
TB throttle body
TB timing belt
I typed up a copy and uploaded it to my Dropbox. The link can be found HERE. I figured some people like myself would like to print off a copy in case they needed it. Which I know for certain I will more than a few times! Might have to get it laminated...Anyway, thank you @Sandroad for putting this list together! This is what the MUD community is all about:cheers: Sooo FAQ?? @Trunk Monkey @e9999
Look for others that are missing (IFS and AHC are def. 2 big ones) and then I'll compile a final list for the FAQ.
Dif
UCA
Frame thingy (nah... make'em work for that one)
TB - torsion bars
