The way to test it systematically is:
1. Check if the coil can make a spark. Disconnect the wires at the coil, run a wire from battery + to coil +, momentarily ground the - and check for spark. If you get a spark then:
2: Check if the ignition switch circuit works: Reconnect the wire from the ignition (ballast resistor), turn key on, momentarily ground the - side of coil and check for spark. If you have a spark, then check ignitor. If no spark, check wire connections and ballast resistor.
3: Check ignitor: reinstall wire from ignitor to the - side of the coil now everything should be connected back to stock condition. Turn the engine until points are open, turn on key and momentarily short between the points and check for spark. If you have a spark, then check point gap, clean points. If no spark, remove ignitor wire at - side of coil and connect - side of coil directly to the points wire coming from the distributor. Check for spark when turning over or see if it starts/runs.
