- Joined
- Jun 6, 2005
- Threads
- 80
- Messages
- 1,505
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
I used the OEM LC strut spacer (P/N 43136-60020) which I believe is a 3/8 inch metal spacer that stacks on the front strut tower.
So it's mounted in between the strut top hat/mount and the tower? That's a pretty simple spacer, and not a bad price really. Sure, the installation would take some time, but that's a lot to have to pay a dealer to get it put in. Dealing with the KDSS is a bit tricky, but all you'd need to do is get that strut and LCA to drop about 2" to be able to get that spacer in.
I'd do it just like the 4runner front end (assuming it's all very similar in design). Relieve KDSS valves, disconnect sway bar from LCA, disconnect tie rod ends, then remove bolts holding ball joint to LCA. Undo top and bottom strut mounts, then lower the LCA to get the strut assembly down enough to put the spacer in. Then reverse the process and tighten KDSS valves once it's sitting on the ground on the tires.
I have no idea, but I wonder how much down travel the LCA could go if you disconnect the top hat bolts (3 of them). Probably not the 2"+ that you'd need, but that would be pretty cool if it could be done, and fast too. Like 10 mins per side. I'm probably dreaming now.
