Like may before me, time has taken its' toll on my wipers. Of course they decide to die when it was raining yesterday but I was able to get home safely.
Today I remove them from the upper windshield frame for a quick clean and lube. I think this is the second time in the last 39 years. When I opened things up there was plenty of lube but the drivers side shaft was now frozen in the housing. I missed this clip on the passenger side during disassembly but caught it before it was able to get away and end up lost forever.
I got lucky and didn't damage it just driving the shaft out of the housing. I didn't see the ring opening and just thought it was the edge of the shaft. The drivers side came off with the aide of a pick and small screw driver.
Also, there are washers on any moving parts and sometimes on both sides and in one case more than one.
This time I chose to use less lube during re-assembly. I also used Super Lube, a Teflon lube, instead of grease.
Once things were back together and the housing mounted to the upper windshield I tested them before installing the wiper arms. This did two things, it verified that everything was working and it also positioned both shafts in the wiper arm raised position.
Good luck on your next rebuild.
