Window roller jumped out of the channel why? (6 Viewers)
Fort Collins, CO
What would cause this green roller to jump out of the window roller channel? The symptom of this was that the window wouldn’t roll all the way up. Once I got into the door, I was able to put this roller back into the channel and the window work rolled all the way up.
I’m sure this will happen again if I don’t fix something. What is that something that caused this roller to jump out of the channel?
Is the grease supple ( not tacky / dirty ) in all grease zones, also clean the vertical tracks out. If that’s all good the regulator is possibly bent. Usually when I see that in any other cars shizz is all gummed up. Your stuff looks purdy clean but looks in photos on a tiny phone screen can be deciving.
Already mentioned, something is bent, loose, broken, etc as the the green roller wheel should not come out of the track if everything is correct. Whatever the cause (glass/regulator loose/bent it) should become apparent once you get the door panel off, open the vapor barrier, and watch the regulator and glass move while pressing the up-down switch.
  • Back
