I went ahead and did the distributor o-ring job and all went well until it didnt start after finishing the job. I did notice I couldnt get the rotor to point to the 11 o'clock on reassemble....it wanted to end up at 11:30 but was still pointing to wire #1. After several tries and no starts I set the flywheel to TDC Zero and the rotor pointing to 5 o'clock, pulled it and lined up the notches put it back in and it pointed to 11 o'clock and it started. I thought for sure it was pointing to 11 o'clock when I first disassembled....maybe not. But will an 80 start/run if the rotor is off 180 degrees?.....is it firing one cylinder ahead in timing? It feels like it is running fine.... I just want to make sure I'm not doing damage long term. Hopefully I just had a "
moment" when I first disassembled and should have cranked it to zero one more time and hope that someone knows that it will not run if set 180 degrees off.
