I ordered a hybrid 2.5" OME lift kit (850 - heavy front/860 - medium rear) and a caster correction kit from MetalTech4x4. I ended up receiving their caster correction plates, which is designed for a 4" lift. I was expecting the caster correction bushings that usually come with the 2.5" OME suspension kits. Do you guys know what issues I may run across if I over-correct caster? MetalTech told me that there shouldn't be a problem. I plan to install the coils and shocks, then get the alignment checked, then decide whether to install the kit or not.
The only thing I have installed up front is a 115lb AOE bumper. I have no immediate plans for a winch or secondary battery.
