chapel gate
GOLD Star
rebuild every 300k?? thats 186000 miles! WTF are you boys putting in your tanks?Ha, bull sh*t. It’s normal to get 1m km plus from them here. Something almost unheard of in the V8s. And before you bring up the high mile US ones remember australian conditions (dust, heat, poor roads and long distances) are much harsher than US - nothing lasts as long. On paper FTE is mediocre - in practice it well truly lives up to its reputation of the best 4x4 engine ever made. If the V8 is so good, why aren’t there multiple groups and thousands of people putting them in everything from 40s, 60s, 70s, 80s, 105s, patrols, Jeeps, boats and more? Because the V8s aren’t as good. Why are people prepared to pay exorbitant prices for high km engines? Because FTEs are the best.
Because quite frankly no other engine offers the combo of high power potential, extreme reliability and longevity, smoothness, fuel economy, cool running and compact size. FT comes close but the VE pump lets it down as it needs a rebuild about every 300k, it’s common for FTEs to do 600k easy before pump work.
It has absolutely no serious flaws, even running 400rwhp consistently in 40*C+ ambients. So yours had a faulty TPS, not exactly a catastrophic failure - it probably just needed a good contact cleaning. And the V8 throttle pedal is just as likely to fail in just the same way.
The turbo is probably the shortest living component (short of timing belt) it’s true - but if you want any improvement in power it’s sensible to replace this anyway.
compared to the FT - the FTE has upgraded pistons, upgraded rods, improved air and coolant flow through the head, improved exhaust valves, better bracing on the block, higher fuel flow and pressure, higher power (and much higher potential) and better economy.
2UZ are great engines, but to try and claim they’re better than FTEs makes you look ill informed. Same with FTs to a lesser extent.
for the record, the FT will always win out for me due to its simplicity, and nothing starts as well as an FT..
