I was trying to figure out what was so different. Perhaps a better pulley, compressor, or wider belt... I guess it doesn't matter as long as my equipment is stock hence I can be sure I'm getting the right belts. Although if the compressor is improved in the following year, perhaps I should check it out.It's the belt that goes around the AC compressor that is different. Apparently this correlates with different compressors used. Not sure what to tell you about "8/88 build". I suppose you would need to search for parts based on frame number or VIN.
that year was the 3FE engine.If your in the market for belts I went to my local Toyota dealerships part department today actually. And got all 3 belts (2F with AC ) for 60 bucks Toyota belts I'll have them in 2-3 days
@ToyotaMatt thanks for the low down. I really don't want belts made in Bangladesh.
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
