I am pretty sure the hole center on 80 Drive shafts is bigger than other cruiser stuff.
I have recently installed an FJ60 clutch pedal assy into my FZJ80
I have recently installed an FJ60 clutch pedal assy into my FZJ80, and am using an FJ60 split xfer case behind my NV4500 - basically the same thing you are doing, except mine is behind a 6.5TD. i've got pictures of the pedal install, and will have pics of the xfer case install this weekend.
The driveshafts will not bolt up to the split case, but you can mix/match the ends to make it work as the driveshaft splines are the same. You'll probably need to change the length of driveshafts anyway...
FYI- 4BT swaps has an excellent sticky on trannies and the nv4500 has its own section. The info for the 4BT cummins applies as the 6BT is the same front and back minus two jugs.. Keep us posted!
I have recently installed an FJ60 clutch pedal assy into my FZJ80...
x2 on the please please post pictures and details of how you made this work. I have a 60 series pedal bucket in the garage and from my measurements it does not fit my 80 without major modifications.
anyone hit up MAF or SOR for clutch pedal bucket
