Clear outdoor silicone on mine
Where are those drain holes located? My cab stinks after heavy rain so no doubt they are clogged and theres got to be a leak to go with it.Did you check your drain holes at the bottom of the truck to see if they're clogged? I recently had luck using a big zip tie to clear mine. I was greeted by a stream of dirty water after pulling the zip tie out of one hole.
They are little slits along the rocker panels by the pinch seams.Where are those drain holes located? My cab stinks after heavy rain so no doubt they are clogged and theres got to be a leak to go with it.
Are all the plugs supposed to be in the rockers? all but the closest ones to the front are. Wasn't sure if supposed to leave them out to drain water or not. would have to seal them off if water has a tendency to get in there and then sit and rust.The sunroof drain pan has drain holes in the corners. You can get to the front 2 but not the back 2 without dropping the headliner. The drains he's talking about are on the bottom of the rocker pinch weld. There's also plastic plugs you can remove to drain the rockers. Do some searches on "sunroof drain" and you'll find plenty of threads with info and pictures.
I totally agree with 5200. I used to live on boats literally and this stuff is a fix all. I use it in place of anything non motor related. I wouldn't use it for a temporary fix, it does not come off easy. Good call, Marine7.For that application, seeing how it’s subjected to constant water. (At times) I would use 3M 5200 Marine Sealant/ Adhesive. That’s what I use on my boats, and it remains flexible ( yet doesn’t “smear” or “ push away” from seams), doesn’t turn “yellow” like regular caulk does, and it WORKS! I cannot recall anything that I’ve used this stuff on that has later leaked! That includes my “under surface” LED ‘s which are bellow the water line 24/7/365 on my bigger boat. I know West Marine sells it.... cost a little more, but worth it! Good luck.
So do they not make a replacement seal for the sunroof? I find that hard to believe. Also, has anyone noticed that their sunroof does not seal up level with the roof? Mine looks as if it doesn't raise up all the way. Looks lower than the rest of the roof. Also I read of people extending that drain tube down through the hole below it instead of letting it drip through the weep crack specifically made for it. I figure the less water in contact with metal the better.
Well s***.. Thanks Built. I have heard of people doing the tube repair. Are they just gluing a strip to the remaining seal?No replacement seal. Must buy a whole new glass assembly from Toyota to get a seal.
Can do a "bicycle tube repair" to improve the seal.
If it's not flush on one side only, you probably have a broken cable on it. That's what I have and I have not had time to get it pulled and replaced / fixed. I'm going to find a complete replacement sunroof assembly, go through it and clean / lube / fix it, then drop mine out and replace so my down time is minimal.
Mine has one side that cannot raise to the top and I have it duct taped shut right now.
Didn't think about a cable being busted. it doesn't struggle in any way or go up/back crooked. Ill look into it. Thanks again.
thanks
Hmm.. Thanks Patrick I think Ill do the same and rust proof the s*** out of it.I pulled mine and tossed them. I feel like if they're open water will always be and to drain out.
