Which oil are you using? (2 Viewers)
It does keep the Jiffy lube places making money so.. :D
^^^ Agreed... For the first year of ownership I have been changing about every 3 months simply because there was no documented history on the vehicle and I would like to get it to a good point. Doing this has pointed out a few leaking spots (oil pan or rear main, valve cover, possible side rod inspection cover) so I will continue to do this for another oil change or two and then go based on my mileage and what I get back from BlackStone when I get around to sending in the information sample.
He says Zinc is a good thing... no debunk that I can see... just a marketing spin put on to justify what they sell.
Yeah, Jalopnik's headline is not accurate as usual. I think the takeaway is that that dude's opinion is that current ZDDP levels are fine except for break-in of flat tappet engines.
Plenty of reason to do it this way. Scientific fact for one thing, All conventional oil will begin to break down after being run in an engine, after 6 months oil will lose much of its lubricating properties from the chemical process that also breaks down additives.
If oil didn't break down, then there would be no reason to ever change it. All you would need to do was change the filter once every few years or so regardless of mileage. If your drive consists of nothing but stop and go driving and short trips like me, then you need to change your oil more frequently regardless of miles driven. The official toyota schedule for severe duty says oil should be changed every 6 months, even if you didn't drive very far, but no more than 5,000 miles between changes of oil and filter.
For those of you changing your oil only once a year...you're doing it wrong.
To take it to the obvious ludicrous extreme, how often should I change the oil in an engine in storage? Can I go with the regular duty schedule, or is it considered severe duty since the oil doesn't get circulated much?
Please back this up with facts.. Not the fact that oil changes are necessary, but your statements of how often they are required.
I am using Chevron Delo 400LE. I bought 10 gallons of the stuff for $113 at Wal Mart on sale. I change my oil every 4 months regardless of mileage.
Its not hard to look in your owners manual and prove that to yourself. Toyota recommends 6 months between oil changes (severe duty) regardless of miles driven.
http://hugh4prez.nate-online.com/Cruiser and M416 Manuals/1986 Maintenance.pdf
See page 7
You went from every 4 months no matter what, to 6 months as recommended by Toyota in 198something. Oil has changed a bit in the last 30 years..
Again, please show scientific (your own words) that oil left static for 4-6 months needs to be changed.
Show me the data that backs your information up.
Here, I'll start
https://www.google.com/search?q=how...j4&sourceid=chrome&espv=210&es_sm=93&ie=UTF-8
Here, I'll start
I said 4 months no matter what? LOL you need to have your eyes checked. I never said any such thing at all. Toyota specifies 6 months, that much is already proven.
If you don't believe that conventional motor oil degrades over time in a 1930's tech engine with a carburetor, then far be it from me to try to prove otherwise, but I will give it a shot.
http://www.motor-oil-engineers.com/Motor Oil Engineers PDF.pdf
http://www.carbibles.com/engineoil_bible.html
http://www.kewengineering.co.uk/Auto_oils/oil_degradation.htm
http://totalcarmagazine.com/tech/2013/04/23/do_infrequent_oil_changes_kill_the_engine/
This test shows the oil was degrading after only 5 hours of use, significantly around the piston land area due to extremes there.
http://www.tytlabs.com/english/review/rev383epdf/e383_036moritani.pdf
This paper says that the oil has begun to degrade as soon as it begins to change colors
http://www.lubeng.com.au/assets/files/technitips/068_Motor Oil Degradation.pdf
http://www.upmpg.com/lubricationnews/why_motoroil_deteriorates/
Scientific fact that engine oil breaks down over time after you use it.
BTW, why so much rancor over my conservative approach to changing my engine oil more often than you do? Do you just hate to see people spend their own money? I also wax my vehicles 4 times a year too and change the antifreeze every 2 years.
Even if they don't need it.
It's cool, change as much as you like. It's still a trivial expense in the life of a Land Cruiser. Delo is good stuff.
I've adopted a different approach, that is easy to think about and remember. I change every 5000 miles on the 5000 miles on the odometer. So 150K, 155K etc. It's easy that way and I don't need a sticker to tell me it's time to change. It averages out to about once per year on the Cruiser fleet and twice per year on my wife's car.
As we have discussed before, it is more important to have a schedule, and stick to it, than exactly what the schedule is. If you are changing 3 times per year, you'll get good life from your motor. You feel good, your Cruiser is fine with it, everyone is happy. Others get nutty and get weekly oil analysis looking for non-existent problems and that's cool too. They are happy, Cruiser is happy.
So, 4 months, 6 months, yearly, all will work fine. No matter what, it won't last forever, but will likely last decades with few issues. Remember too, that if your truck uses any oil, and you check and replace, then you are continuously replacing the additives and can cut your change intervals a bit. But at 3x per year, with a good oil like Delo, you have one of the best maintained motors in the USA.
Yep, obviously my eyes need to be checked... Toyota recommends 6 months in harsh climates. It's not proven with modern oils. Just recommended with 30 year old oils...
Okay
The only way to know for sure is to go by the oil
manufacturers specifications. This can also be verified by oil analysis testing at different
intervals during use. There are two manufacturers that specify 25,000 mile/1-year drain
intervals and only one that I am aware of that specifies 35,000 mile/1-year intervals and
yet another that specifies 5000, 7,500 or 15,000 mile drain intervals without by-pass
filtration. If by-pass filtration and oil analysis is used, then drain intervals can be
extended until the lab results indicate the oil needs to be changed. This can be many years
and several hundred thousand miles depending on the variables.
Huh.. So many years depending on the oil huh...
a 2005 Consumer Reports article discovered that some engines from Audi, Chrysler, Saab, Toyota, and Volkswagen appear prone to sludge almost no matter how often the oil is changed.
Interesting....
Oddly enough that article has nothing on actually oil change intervals. It does recommend that you do not use oil that is over 3 years old tho..
The actual Oil Change Interval (OCI) varies, but a lot depends on the driving style as to exactly when it needs changing. For simplicity, most manufacturers now suggest 12k miles or once a year as opposed to every 6k or even 3k miles that used to be the norm as recently the mid 1990s in the UK.
however, with our classics, the simple "Oil Spy" type test as used by mechanics over the years will identify when the oil is due for a change. But, your classic car’s handbook states every 3k miles or possibly every 6k miles. Which is correct for that era when the oils available weren’t to the same quality as those available today. As late as 1980, the MGB handbook for the B Series engine recommends an OCI of 6k miles and six months whichever came first whereas later in the 1990s the A Series was 6k miles or 12months, whichever came first.
huh.. 12 months...
However there is another approach concerning the flexibility of oil change intervals. The more you push the pedal to the metal and the more you drive with a cold engine, the sooner the indicator will show that it's time for an oil change. While theoretically you can drive up to 40,000 kilometres without the oil being changed, in real life this period will hardly reach 20,000 kms.
psst.. 20,000 kilometers = About 12K miles... And again no discussion about time..
No, the oil at the lands was changing after 5 hours of use.
In this study, the condition of the oil in the crankcase barely changed
BTW, I love the end of the paper that states that figures 5, 7, 9, 10, and 11 were incorrect for a couple years Pure confidence there....
No, it says the oil is designed to change color so as to not damage the motor..
First of all, the detergent additives used in oil are designed to keep the engine clean by holding the contaminants and
deterioration products as finely divided particles in the oil itself. This keeps the engine clean, but it does make the oil look
dirty. If the oil is dark brown or wine colored, it is usually due to the oil oxidation products and varnish-like materials already
mentioned. Actually, it is much better to keep this debris in suspension in the oil than to have it drop out of the oil as
varnish on the pistons, rings and grooves.
It also says there is not definite numbers to change the oil by..
Therefore, the best and most economical procedure is to drain the crankcase at reasonable intervals
and to refill it with fresh oil. This reasonable interval is not easy to establish for a wide variety of
operating conditions, but the industry has worked out recommendations for various types of oil,
operating conditions and engine designs based on a great deal of experience. Oil analysis can also be
used to establish reasonable, safe drain intervals.
Even Amsoil ( a great synthetic that you do not admit to using) maintains that they can go much longer than conventional dino oils.
Not only do AMSOIL Synthetic Motor Oils provide protection that is superior to conventional oils, but they remain fit for service many times longer as well. Heat and oxidation are the main enemies of lubricant base stocks. The excellent resistance of synthetic lubricants to thermal and oxidative breakdown allows them to be safely used for much longer drain intervals than conventional lubricants. Their uniform and smooth molecular structure allows AMSOIL Synthetic Motor Oils to operate with less friction and better heat control than conventional lubricants.
Of COURSE it does. However, that does not mean that it is not protecting the engine properly. Tires wear the second they hit the pavement as well. You replace them every 300 miles?
It's simple. It's not needed. Telling people that it's a good idea to change your oil every 3K or 4 months is a good idea and they are "doing it wrong" if they change their oil yearly is silly. It's not an absolute. If you drive 75K a year, every 3 months may not be adequate. But it also may be fine because of the driving conditions.
Your best bet is to get your oil analyzed and see exactly how long your oil can go. If not, you are generally wasting oil and money. And I hate to see people wasting their own money...
Where do I say you have to change the oil every 4 months no matter what?
Where do I tell anyone that they should change their oil every 4 months?
Where do I say oil sitting static goes bad?
Toyota doesn't claim 6 months in harsh climates, it claims 6 months of harsh USE, which means dusty conditions, cold starts, stop and go traffic, lots of idling etc.
I would question your ability to read anything and come up with an accurate representation of the information you just consumed.
I do appreciate the fact that you are trying to save me the $70 a year extra I am spending changing my oil so much, but I will continue to do so even to your dismay.
Think of frequent oil changes likened to fire insurance, you pay extra to have it, probably won't ever need it, but the alternative of not having it could be costly.
Ok I think that is enough of the back and forth on who's e-$%^ is bigger. Suffice it to say that people will determine, based on THEIR OWN METHODS, what is a proper OCI for their particular application. One OCI does not make it equal or greater than another as there are too many variables to consistently get the correct answer. Smartypants - I think that is what Mace is trying to get across. There are recommendations within the manual that were created for the time that the manual was done. HOWEVER, that does not necesssarily make them correct, think of them more as guidelines.
As I stated before, my father was an ademant man about changing oil in all the cars at 3k miles (and he only EVER used Pennzoil) and refused to pay someone money to do it (if he hurt his back guess who was under the car changing the oil :) ). Anyways, over the years that changed as the needs of the vehicles (as they became newer), our driving habits (they did a 60+ mile commute daily), and money really changed. Now with their new 2011 Honda Pilot he changes the oil (again he is now 70 and does it himself) on the recommended 7500 mile interval as stated by the manual (and believe it or not that big ole V6 only takes 4qts!!) or when he has time. We have gone from a society that relied on doing the analysis ourselves to relying on an idiot light that tells us when we need to change our own shorts.
And just to clarify - in your first post (Smartypants) you did state that you change the oil every 4 months regardless of mileage. Mace questioned this stating there is no reason to do this which is what lead to the above spiraling tyrade. You apparently have your set reasons as to why you do this and that is fine, I think Mace was just trying to state (since you have a very low number of posts and I personally have not seen an introduction stating what your mechanical/vehicle background is) this was not necessary to try and help a new member out (which is what this forum is all about!!).
Anyways, back to who uses what! I received a $25 Walmart gift card from my chief for my bday however I refuse to go into a Wallshart (personal reasons that I can explain if needed) but don't want to give it back to her. Thinking of going and grabbing a pint of MMO to add to my next oil change but really have an ethical issue with this as I have not been into one in over 7yrs. Decisions decisions.
lol okay amigo.
Way to prove your point ;)
BTW,
You really should replace oil every 3 to 4 months regardless of mileage. Over time the oil breaks down after it has seen some use because of chemical changes from being in the engine. This can be a major cause of wear over the years.
Hth
Good post. But one clarification. Just like modifications, I really do not care what people do to their own truck. If a person honestly believes in doing something a certain way, they are going to do it anyway. The guy that removed the front inner axle seals so that his bearings could be lubed by gear oil comes to mind. Land Cruisers are what their owners want them to be. The problem is when someone that may not have much background knowledge hops on the computer and reads this thread on which oil to use in his truck. He sees a post by some guy stating strongly that he changes his oil every 4 months no matter what, and takes that at face value. So he does it as well. And wastes his own money. :meh:
But one clarification. Just like modifications, I really do not care what people do to their own truck. :meh:
You obviously CARE A WHOLE LOT. Otherwise you wouldn't have spent HOURS UPON HOURS trying everything in the book to make me look foolish, you even went so far as to use a quote from an entirely different and unrelated thread to try and keep your ego happy.
Your trying to save me a buck by telling me to get oil analysis, which costs more than the oil change and does nothing to help the oil. I will save the money from not following your advice and just be ensured that my oil is in tip top shape at all times.
You shouldn't assume that low post count= someone with little knowledge or skill, just as i assume a high post count is not always a reflection of skill, but could just be ego inflating behavior and not in a true spirit of helping others.
Oil breaks down over time, undisputed fact.
Also Toyota's 6 months between oil changes wasn't just a "recommendation" if you didn't do it you voided your warranty. So if they recommend you change it every 6 months regardless of mileage, then I would think that would suffice.
Oil changes are cheap and quick and easy to accomplish, oil disposal isn't a problem. What's the big deal?
Gonna go change my oil now, have a nice wonderful, fun filled, and adventure packed day.
