Anybody know what type of plug is needed and where I can get it for this?
That port is 3/8NPT.
<insert pimping>
I have the following for sale:
1/4NPT plugs for AIR ports, some intake manifolds;
3/8NPt allen plugs for the t-stat housing;
1/8NPT for some intake manifolds, brake pressure switches.
<end pimping>
You planning on cutting that pipe once the engine is installed. Looks like it will be dragging on the ground.
Jeremy
1st red hole: 1/4NPT
I think the hole in the t-stat top is BSPT. I tried a 3/8 npt gm sender and no joy.
The small holes in the intake are actually 1/8BSPT, which is slightly smaller than 1/8NPT. I run the 1/8NPT tap in the holes a few extra turns.
What is supposed to go in the hole with the green circle?
My vehicle came desmogged and the PO put a BVSV in the whole. From what I can tell from the Toyota Emissions FSM, I don't see any emissions parts going there. So that leaves the question of what DOES go there?
I am needing to put the emissions back on to register my vehicle in Utah so I need to know if I am missing something.
