Whats the largest tire I can run on a stock 40 series
I'm running 32x10.50x15s on 8 in rims. I don't belive there is any lift (not by me for sure) possibly longer rear shackles. Trimmed rear fenders. Only rubs steering rod when fully turned, other than that no probs. I will be adding spacers soon to remedy this.
Quote: "Only rubs steering rod when fully turned....."
That brings up a good point. My 33 x 12.50's were just barely missing the tie rod ends when fully turned. But, and here is the problem, the RH tire was rubbing against the 90 degree zerk fitting on the tie rod. It was starting to groove the sidewall, and if unchecked, could have cut through it like a lathe bit. I replaced this larger zerk fitting with a much smaller one and that solved the problem.
green73 said:
DAMN! I need pix of this new rig. You got the bug pretty good. 1st the LV, now a BJ44! Did you find this one in Japan? Also is there any news/updates on the LV? If you are still in Japan, see if you can get some Symex tires for that new rig. I am not sure if they sell them there, but I know they don't here in the U.S.
Yep, more like an addiction than a bug. Picked up the 44 up near Tokyo close to the center of the island and trucked it up. Everything north of there rusts out. Its alright save the normal door, sill, and floor issues, no other body rot. Several really clean 44s but they cost a lot more than I had in my budget. Thought there'd be lots of LC parts here but either they rust out or they're crushed. The LVs in storage in Iowa. Got home last month on leave and drove it for a week - what a hoot. With a little luck it'll be painted this time next year. Gotta run pure snow tires here - 200+ inches a year I need a really soft tire.
Teach me how to post a pic -
step one buy a star. that allows you unlimited pic posting, other wise you are limited to like 6 at a time.
click on USER CP
left colume
down at the bottom
click paid subscriptions
it's 20 bucks well spent.
after that(or before that, it's the same either way)
when posting a reply
below the submit reply and preview post boxs, there is a section entitled "additional options".
in that section is a box marked ''attach files'', with a clickable box labeled "manage attachments"
click that and download photos right off yer 'puter.
but be warned they must be under a certian size orther wise they will get bounced back.
I run 35x12.5x15 AT's on road an 35x10.5x15 Simexs off with no body or suspension lift.
2005 with Simexs and old paint job.
2006 with AT's and new paint job.
No suspension or body lift and NO rubbing:cool:
