What trailer tires do you all use?
Stumpalama
Forum Junkie
NOVA
Website
www.capitallandcruiserclub.org
Looking to replace all 4 (5) of my trailer tires before RR. I am moving up from 205/15 to 225/15 to get the trailer more level and add some clearance. What brand do you all recommend or not recommend? I see lots of deals on Amazon, but I don't want to go cheap just to save buck and regret it 300 miles from home.
@Tikicruiser no Cove cracks necessary. :poop:
Maxxis M8008 10 ply radial
I've heard good things about maxxis trailer tires
I’ll have to look at mine. They are an off brand but have held up good. I’ve had one go bad but it was a passenger front so I probably hit a curb and broke some belts in it.
I started using truck tires. I was going with a Firestone commercial tire a few years ago. Started with two and was going two replace two more after 19 cmcc trip. But had a two tire blow out so had to buy cheap tires. They are not wearing as good as the Firestones. What ever tire you go with balance them.
I moved to American-made Goodyears on my race trailer. Most of the trailer tires out there are chinesium, inlcuding some of the Goodyears.
@matzell do you have access to these? If so I'd prefer to support local business and source them from you. Otherwise I'll support the evil behemoth: Amazon product ASIN B004QL6I0K
Yes. I think the ones you posted are the 8 ply version . I can get both 8 and 10 ply. about $10 more per tire. I will check pricing when I go in to work Sunday and check. I am a Maxxis authorized dealer so I can get most any of their tires. I do sell a lot of these trailer tires. They cost more but hold up well. I can also mount and balance them for you if you bring the trailer down or you can bring me the wheels, whatever is easier.
Yes I always balance my trailer tires, makes them wear so much better and a smoother ride.
Looks like I'll be planning a trip to Richmond..
Is there a compelling reason to go with the a particular ply tire, besides just more plys is more better?
higher load capacity for when you overload the trailer. 10 ply offers about 300 lbs more so about 1200 lbs more per trailer. Keep in mind axles and springs have to be up to it as well. The higher load the "tougher" they are when hitting curbs, ditches etc. You may not need the 10k winch, but it pulls better than the 8k unless it is a 8274!
I have 14 ply on my race trailer because I can!
Copy. My trailer is an open deck, so a bit lighter than others when loaded up. I will go with the 10 ply, as I'd really love to make it through a full year without having to replace 2-3 tires.
STOP HITTING s***!
Now I’m going to hit something and blow a tire!!!!
Really? Is it because crappy tires or over weight or like chris said you can’t drive 😂
I had a bent spindle up until this last year when I replaced the front axle, so swapping tires around, starting from the ones that came with the trailer, as the front wore funny forced a steady stream of replacement tires. I've only had one blow out due to hitting something and that was the Cove last Fall... the same rock you @mwalls54 ricocheted off, IIRC.
My trailer driving has always been suspect.
that would be frustrating and expensive. And for the record that rock jumped out in the road lol.
I think if you have gotten the bent axle fixed you will be good! And that may have been your “tail waging the dog” problem you had when you first got it.?.?
I’ve had the same tires on 2 different trailers for several years. But I do need to get a new set. I’m running my spare and it is plugged from a screw hole.
I am moving up to a taller tire to get some clearance on the trailer and level the nose to the truck, since I will also be adding an inch or so to the truck when I get around to installing the lift.
Stick with 10 ply trailer tires. They hold more weight per tire. The sidewalls hold up better and if they ever go light from underinflation or you just overload it the sidewalls will last a bit longer longer
