what "trail spares" do you carry
This give me a start. drive shaft question. I know the front is much more protected from impact. But does it still tend to fail from stress the way a rear one would?
Driveshafts don't fail from "stress", they fail from getting pounded by rocks. Once the tube is compromised it can twist and cause all sorts of woe and strife. As far as the front driveshaft goes, I've had the same one for 25 years. It's very well protected.
If you try hard enough, you can break anything regardless of tire size. I've been wheeling in the rocks with 36" Swampers since 2004. I've bent driveshafts and steering linkage and other assorted parts that have either been replaced by stronger ones or simply OEM ones, but I don't hammer my truck. I enjoy wheeling very technical trails, but I don't beat on her. She's my daily driver and I need to get to work on Monday.
HARD BRAKE LINES
Surprised nobody mentioned this one, or maybe I'm the only one who's ever had one taken out on the trail. Nothing fancy here, you can buy 3-4 different lengths from NAPA, its all generic straight lines with the m10x1.0 thread pitch. Or they will say Japanese on the label. Anyhow, they are about $5 a piece and take up almost zero room. You bend them by hand or you can buy pre bent OEM ones for about $5 a corner but they are less versatile. One of these and a quart of brake fluid would have saved me a lot of hiking back in September.
@jonheld do you cross over into PA to Rausch or hit the Pine Barrens to wheel?
HARD BRAKE LINES
Yeah, I mentioned them too. :hillbilly: I'm really fond of the front passenger short pre bent hard brake line that gets cut when the front passenger sway bar mount lets go!! It's a cheap insurance and only costs few buck from Toyota. Also I suggest making up a short, straight piece of hard line with the same fitting at both ends. You can use this as a gender changer if needed.
Exactly what happened to me up at the top of wheeler lake !
No s***? Yeah, that can ruin your day if you don't have the correct part!!!! My sway bar mounts are reinforced but still, I QD the front one if rock crawling. This happened to a 100 series buddy of mine as we were climbing a long uphill and THAT'S when things got interesting!!!!
Man, after reading all the stuff you guys carry, i guess I'm getting really old. When i was younger i use to take my 4X4's out and beat the crap out of them, (rolled over more then one) plus i couldn't pass by a mud pit without seeing if i could coat every inch of my truck in it. Now that I've gotten older, and seeing the real cost not only in money, but also to my body, i now find it less expensive to take the easy route. So i guess I'll have to leave all the hard core rock crawling to those younger then me. That's not to say I didn't do my fair share of trail side fixes, but now I'd rather keep the rubber side down, and bring my rig home without any non factory dents in it. Plus it keeps my wife happy too, by not having to explain to her why i need to spend OUR MONEY, on parts for MY land cruiser!
@rc51kid- What type of terrain makes up the majority of your off road adventures? What part of the country? Sure it's a warm fuzzy feeling to know you have two of everything because we never know what our mechanical challenges will turn out to be.
The Rubicon and Fordyce trails are in my back yard so rock crawling makes up the majority of my wheeling for the past 26 years. I have damaged rear shafts but never beyond trail use. Toyota drive shafts are notoriously strong. Perhaps it would be a good idea to take your shaft in to have the tube upgraded to something closer to .100 thick material. I believe mine is .095. it balanced out well and takes some descent hits without giving up. I have a spare rear shaft and plan to start taking it along.
Take A 4' piece of ABS pipe to use for separating a birfield from the inner axle. Slide the shaft into the pipe and then thump the end of the ABS on a rock. The shaft should drop out of the birf. Take extra birf keeper rings. How about a spare set of tie rod ends.
I have done a lot of wheeling on tough trails and have had minimal serious problems As mentioned before, common sense and careful use of the skinny pedal combined with choosing sane lines in an 80 that has been properly prepped is most important.
You could always hire a chase truck so you still have room for food and camping gear in your personal rig if you like to wheel with a heavy right foot. I have a buddy we call "Right foot Rich". He is most entertaining.
I usually just do a trail to get where I am going vs a trail to do a trail if that makes sense. But often the trail gets into some " stuff". For example o was going out to a arch in San Rafael and ended up on devil's race track and fix it pass. So sometimes it can be technical terrain.
San Rafael? You are in the Bay Area?
Knuckles are marked R and L so I don't think you can swap sides. Wouldn't that put the brake calipers on the wrong side of the knuckles?
yes it would, I am just thinking out of the box, would rather have to pack just one not 2, first thought was that in a pinch you could use it on either side and remove the caliper on the broken side, but that would make for an interesting drive home.
Include a full set of hoses and belts. These are common causes of breakdowns and are fairly easily replaced on the trail but not if you don't have them with you. It is also a good idea to have a full set of tools. Many of these spare parts listed in this thread cannot be replaced with your standard socket set so know what you need or the spare parts are worthless. I carry 500 lbs of spare parts and tools including my recovery gear (and I have every recovery tool Slee offers). Once you list it out and weigh it you get to 500 lbs pretty quickly. You'll need all of the standard fluids as well.
It is a good idea to have a place to sleep in the truck or have a tent, sleeping bag and pad with you. Some of these repairs take several hours to complete which means you can spend the night in the woods unexpectedly.
Even with all of the items I carry, I feel concerned at times I won't have what I need. I mostly wheel and hunt alone in the middle of nowhere so if something breaks I am SOL and have to fix it by myself. I have had some really long walks to get parts.
The most important thing you can do is preventative maintenance. Get under the truck / hood and tighten / eyeball everything before you leave on a trip! Second most important thing is don't put yourself in a corner by wheeling so agressively you pointlessly break things. A little care can save you a long painful effort.
I cannot possibly imagine what it has to be like to get ready to go wheeling for you people.
