What tool is required to do this? (1 Viewer)
SW Michigan
Wondering what is used to stamp circles in sheet metal like this:
main.php
My guess is a die.
just a dimple die affair I imagine. Simplest version of which is probably just 2 matching "pucks" that you squeeze together (after cutting a round hole).
some electrical supply houses or maybe even home depo have a hydrolic knockout kit you might be able to rent. its pretty much just like E said, a cup and die. supply houses and home depo have a less sophisticated version you can buy. its just the die set with a ratchet instead of hydro. you could try that.
This particular one is a laser cut and CNC combo unit. too pricey for a small shop, ask a local machine shop or steel supplier for help. Most will be glad to.
