what seats can I put in my Landcruiser
thanks guys. The problem I am having is that there is a lump in the floor/transmission tunnel next to the front inside mount. It looks like it would prevent a seat with a wider rail from being used even with new mounts. Unless you went up above the lump, hammered down the "lump" or offset the seat so it is not centered. Any advice how you guys are dealing with this?
Not sure about the "lump", is this it (photo)? My LR seats come right up to the area that rises just before the shifter console
I just got done putting a set of seats out of a Tacoma in my 94 I used the factory bracket as a guide to fab up new brackets for the Tacoma seatsI cut off factory mounts for Tacoma so it was just down to the sliders which are 17 wide the lc sliders are 14 I used 1/4 x 1 flat bar to copy and also lay across to mount the Tacoma seats had to swap out seat belt retainers and turned inside out so as not to ruin if I decided to go back seats are great lots of forward and backmovement they set a little higher than the factory seats but that could because the foam was worn in the factory seats I am 6 2 tall and my head almost touches the roof I may shorten the back of the mounting bracket to lower it 1 inch but will drive it for a while be fore I do may post photos later when I figure out how to upload them so far very happy lots more cushion for my boney butt a little more effort to get in but not bad
OK. Really stupid question here. Black or light tan? I have a 94 with the drak brown interior and figured i would do black seats. But my wife said she thought the light tan would look beter. I never really considered tan. I know it is trivial but what does the board think? Sorry about the hijack.
Here is some contribution.
Looked at some more seats today. Scion TC are going to be a really good option. They are very common, black cloth, manual, no airbags and a relatively low mounting height. These are running $25 each at most U pull where i find them.
I found did find some 2010 Acura RDX black leather seats in great condition. A little expensive at $200 so i didnt get them. Still on the fence.
Hammer Time. I unplug the battery, so I don't make the airbags deploy when I do it, because you have to beat the piss out of it!
Spray with some primer afterward. DONE.
I sourced a set of 2014 Audi A4 S-Line heated seats for Mitch's LX. Without question, the best upgrade we've added. The leather is almost a perfect match...pics make them look lighter than reality (third pic shows seat's color better with an LX headrest sitting on the bottom). These are not the Recaros but the Audi Sport Seats. They have a bit more padding and not quite as much side bolster which translates to more comfort for the long haul. Ridiculously simple installation. The seat rails are flat and 19" apart so the only modification was to massage the little humps near tranny tunnel with a BFH to allow them to be centered on steering wheel. 1/4"x3" plate spanned the Audi mounting holes then welded on the amputated legs from an old set of 80 seats. Simple wiring and all functions work. Ridiculous amount of legroom and super comfy.
Similar to @halfkcruiser you can kiss the dash or butt up against the rear seats with the amount of travel on the slides. Using the 80's legs and 1/4" plate, the seats are about a 1/2" higher than stock. We could easily have lowered them 1" by fabbing shorter legs instead but not necessary for Mitch's position.
Update: I've been asked for more detail on how the brackets were made...didn't take pics. Started by cutting two pieces of 1/4"x3"x20"(might have been 21"...whatever the rails widest points side-to-side were). Drilled holes at spacing of Audi mounting holes 1" back from leading edge allowing the front plate to reach further back and the rear plate to reach further forward. The rear plate will have an additional hole for the locator pin. Cut legs off donor 80 seats and bolted in place to rig. With mounting plates bolted to seats with grade 8 button head bolts/screws, placed in rig atop the legs. Legs have a hole in the top so marked plate thru hole from the bottom and traced around leg flange. Took them all apart and bolted the legs in place thru their holes then welded secure. The Audi seat belt receivers were used with a slight massaging of the LX's buckle. Compared the LX buckle with my wife's S5 and the latch hole was in the exact same place but the tongue was slightly narrower and longer so a little contouring was necessary to mimic the Audi's shape.
Wiring was easy as these do not require an ECM or BCM to operate. I'm not a fan of splices so I sourced the "car-side" green and red plugs (black plug under seat not used) from eBay to match the seats. There are several wires on the red plugs that are not used for this install. I wired the movement Positive and Negative in the red plug (two fat wires...all the others are thin) to a distribution block he already had under the console off his second battery so they are hot all the time so we can move the seats without the key on. The Audi heated seat switches (A4 '98-'04 sourced on eBay) have an integrated relay so no exotic wiring needed and were installed in the blanks on the center console. The heated seats will have several wires running from the seats, switches and power source as shown on the diagram attached. I ran the heated seat's relay trip wire to the LX's power seat leads which are a keyed source and the main heat power to the distribution block a fore mentioned so they shut off with the ignition to avoid accidental battery drainage . In-line fuses were added of course (7.5a trip & 15a power for heat and 20a Thermal for movement). These heated switches have a matching car-side plug which I sourced on eBay but simple female spade terminals would have worked as well. Clipped the seat belt warning wire plug off LX seat and wired to Audi seat belt receiver and plugged in. Attached are a few pics as well as the wiring diagram I used for the heated seats (Audi plugs are visibly numbered).
View attachment 1376260 View attachment 1376261 View attachment 1376262 View attachment 1376265 View attachment 1376267
Amazing!
I just PM'ed this to you, but I thought I would put it here for anyone who might want it:
Sure. But really it is just easier to do what I did than measure. I cut off the old seat bases from the original seats (to be honest, if I did it again, I would fabricate them. They would be stronger) and bolted them in place where they were. You can cut them flush from the bottom of the LC seat carriage so the plate sits perfectly on them. Then I simply measured the distance across the front and back, cut a piece for each side accordingly, then welded them in the truck (carefully! A TIG welder comes in handy here). Then I cut off everything from the Disco seats down to the tracks, welded a cross plate between the two tracks front and back since the tracks were not the same width as the new plates, then put them on the brackets I built in the truck, positioned them where I wanted them and tacked them on in place. I really did not measure much. You would really want to do it in a similar way. If I gave you measurements, you would still have to jimmy them in the truck. Let me know if that makes sense. But I will still get the measurements for you. And make sure to figure out the power connections first and position the seat all the way in either direction so you know what the new travel is. They travel a lot more than the LC seats. I screwed that up and had to cut, then re-weld the seats in a better position. My balls thank me. You will be so much happier with these seats. And the arm rest is awesome!
Great job. Do you have any info on the wiring? I am a bit intimidated by the whole wiring part of the job. Thanks.
Outstanding write up.
Any chance you have some more pictures of these in the car? Also can you get me a measurement of the height of the seat back to the top of the shoulder?
Thinking I'll pull the trigger on a pair of these, just not quite sure how my fat 280lb, 6'6" ass will fit in them :lol:
I think @milemarker60 or the owner had that rig listed for sale a while back? I got seats from a 2014 A4 for the LX. All in all, they (you) sit about an inch or so taller. This is installed on cutoff toyota legs and using 1/4” mounting plates, fully lowered. The biggest difference is the height of the seat back/headrests. Not a big deal but the seats are just bigger and a bit closer to the roof. Also the outboard seat rails and cladding stick out/forward quite a bit. Looks a little wonky with the door open, but the travel range fwd/aft is MUCH better - a big plus for tall peoples.
Other positives; The motor wiring is dead simple. The leather looks and feels great. And they are much more supportive. On that note, by all means “test fit” yourself if possible. The sport line seats MM60 used are a bit more narrow at both the thigh and side bolsters by design. I sat in a coworkers S4 and they were just a too snug for me, (I’m 6’ and 2 bills) so I sourced the standard A4 style.
Audi seats. 2014 I think. Haven't wired the power yet. Way, way way more comfortable. Lumbar support is good. The seats are bigger than the OEM cloth I removed.
Made the base like others with 1/4 x 3 inch flat stock. Bolted the old feet to the new steel base. Gonna have it all hot glued as well when I get around to it. Seats centered and dont touch doors. E brake handle is fine. I did remove some of the hump so that the seats can move for and aft, had to do something about the hump, which is part of the floor structure. You can see that part on a parts diagram online
Thanks for the insight Mr Kaboom :lol:
Taller seat back is a good thing in my eyes.
Might have to try and find an S4 to sit in then.
My bro had an A3, it's seats were too snug for me, but the whole thing was too cramped, so maybe not a good indicator.
View attachment 1790701 View attachment 1790706
Great pics, thanks that helps.
I'm fairly familiar with the floor pan and seat brackets (have looked at options to mod the OEM seat) Looking at those pics, I can see opportunity to lower the finished height a little if needed
I posted this up in the 80 forum - WDYDT. OEM and German side by side. I fabbed mine just a bit different (all welded) so it probably sits about 1/2” lower than @Tedward. His highlights well the length of the seat tracks - his stick out aft, mine more forward. If you had underseat heaters and pulled them, you’ll have even more room to go lower.
Got mine out of a 1991 Mazda mpv van . Seats look brand new and matched ok with my gray interior. Used my stock seat rails and bolted them to the Mazda seats.i cant slid them back and forth as far but I have arm rest now.
@mdkaboom (dr. boom)
Nice job on the install.
Did you wire the seat movement and heaters for keyed power or hot all the time?
Did you tap into a door jamb switch for the courtesy light?
On the red Audi plug; large red, large brown = +/g seat power (Toy blue/white). I kept hot as I wanted to be able to move the seats once out, Key off. Driver side will have one extra wire for seat belt chime (green/white?) you have to dig out.
Same red plug, small black, small brown for the footwell light. I tapped into the Pass door light at the kick panel to see how it looked. Works nicely, but if I was doing it again proper, I would find the courtesy light power coming from the dome/overhead as my kids tend to drop stuff....
Didn’t get around to the heaters, but I think you just need a VW switch/relay, in-line fuse, and ACC pwr. @milemarker60 has solid gouge on the heaters.
What are there differences in the seats and dimensions between a 91-92 fj80 vs the later fzj80?
Can’t vouch for the earlier models, but I’ll try and post up dimensions for the 96 LX450 (guessing they’re the same for the LC?)
