The Sequoia seat has an armrest and looks Ike same power seat controls too! If I was willing to take some time to determine fitment, how would I even go about it? Is it just measuring the bracket holes or what?
@2fpower , is it trial and error?
Forget about the bracket holes, they aren't going to line up. What you will need at minimum is the rail that the donor seat comes on. You will then need to either build a custom bracket to bolt/weld this too and then bolt to your floor. Or, the other option is remove the feet from your OEM bracket and weld these to the bracket on your new seat. For non power seats you can do like I did and buy some universal sliders from summit. They come in a pretty nice kit and allow you a ton of movement front and rear. For instance I can run my WRX seats forward until they hit the dash, or backward until even I can barely work the pedals.
The thing to be aware of is the final seat height. If you are not careful with how you fab the bracket you could easily end up with your head hitting the ceiling.
