What parts are in the power steering seal kit #04446-60080?
For my HDJ80 with the 1HD-FT engine, do I need to order the O-Ring 90301-73004 and pressure line gasket 44327-30030 separately from the kit 04446-60070?
Toyota Norway had never had any orders of the large O ring in its systems ever, they said.
When I told them the part numbers for the large O-ring and pressure line gasket, they claimed these numbers did not match my car.
Somewhat confusing.
O-ring part number is for a fz-fe
Part # for hdj80 o-ring is 90301-60002
Yes you will need O-ring and high pressure hose gasket.
The high pressure gasket is a standard part, universal to many toyotas
The part number below is a substitution for the original seal. The original part number is for two individual copper O-Rings
Thank you. Gold star.
I saw a lot of talk about the bearing. As far as I can see, the bearing is in the kit I ordered.
Can’t wait to rebuild the pump, it is leaking like crazy.
So is the diesel tank:/ JB weld I guess.
Bearing won't be in the seal kit.
Bearing part # 90029-36003 (..)
Thank you again. What a fantastic resource this forum is.
All ordered. Can’t wait to rebuild the PS pump.
I don’t know about previous rebuilds, but the truck has 518.000 kms. Dare we guess on original pump?
Take care.
So if I were to swap out PS pumps with a new 1-HDT one from Toyota USA, are these the following components that are "one-time use" and replaced at the same time? Do I need the gasket kit or only if I am rebuilding?
O Ring - 96711-19019
Pressure Port Gasket - 44327-30030
O Ring - 90301-60002
Should I replace the hose while I'm there? 44348-60170
Am I missing anything else?
