What motor oil type and weight do you use?
What motor oil weight do you use in your 200 series land cruiser?
  • 0w-20
    Votes: 154 60.9%
  • 0-w30
    Votes: 10 4.0%
  • 5w-20
    Votes: 18 7.1%
  • 5w-30
    Votes: 64 25.3%
  • 0w-40
    Votes: 5 2.0%
  • Thicker...
    Votes: 2 0.8%
  • Total voters
    253
here you go
You are interpreting that chart incorrectly.
Both 0W-20 and 5W-20 are acceptable, but if you read the part you chose to fold over in your pic, 0W-20 is preferred under normal driving conditions at all temperatures.
The way the arrow is drawn can be misleading, but it is not meant to mean that 5W-20 is for colder temps and 0W-20 is for warmer temps. It means both are OK for all temps.
HTH
my LX states 5w20 (this is what the dealer has been putting in) for colder weather and 0w20 for warmer. Considering its not unusual to get below -40c here in Canada, what do you guys think? The manual definitely points to 5w20 for colder temps
You should definitely be using 0W-20 oil up there in Canada - it performs better in cold weather than the heavier 5W-20.
HTH
IMO, optimal oil weight is all about operating temperature, both starting and operating temperature. The majority of all oil properties varies based on temperature. So for any particular engine design, the nominal operating temperature dictates oil viscosity.
The major variables to temperature is intended usage and predominant weather.
Intended use in the sense of engine load and output. It would be pretty extreme use to need to go up a viscosity level. General off-roading isn't much load truthfully. One would have to be very deep into the throttle in an extended fashion to qualify as extreme, and even then, the cooling system is sized for just about any load one throws at it. Short spurts here and there isn't that. Something like towing really really heavy loads in the west in the middle of summer, Baja running, running sand dunes and Dubai, or Autobahn blitzes may be that. Otherwise, I would find it hard to see how one would really tax the motor enough for even the recommended engine oil, as OEMs validate the drivetrain oiling and cooling systems to some degree of extreme use. Our 5.7L has a pretty large oil to water heat exchanger, backed by a large multi-row radiator. So elevating the engine oil temperature substantially is unlikely.
A Toyota motor won't die if you follow the manufacturers recommendations.
Now if you modify the engine substantially that it's making XXX more hp...
Why would the dealer have been using 5/20 all this time? Stupidity? Thanks for your feedback by the way. Next change I will get 0w20
Toyota 5-20 is conventional, and cheaper than Toyota 0-20 which is a synthetic.
They are basically making more money every time you pay for an oil change.
Id look to go somewhere else if they do.
Only one dealer around where I am. Not sure if my local private shop has ever seen an LX lol
You could always buy the oil and take it in if they want to charge you more. I've done that years ago when synthetics were just starting to get popular.
I prefer to do the work myself (I have three Toyota dealerships near me and don’t trust them — when I know more about the LC than they do it’s not a good sign) but if I don’t have time or whatever, I supply my oil Amsoil Signature Series 0W-20 and filter (either TRD or Amsoil Absolute Efficiency), diff oil (with a hand pump cuz they claim not to have any since they put their’s in by hose), and any other parts, Toyota or otherwise, in order to get the best price possible and/or to support vendors here.
I always take in a Blackstone oil analysis bottle and a plastic bag for the used filter
I am probably going to switch to Motul 0w20 as I can get it for the same price as Mobil 1 and hand that to the dealer when I don't get a chance to change it myself
Been using the recommended 0w20 but in an effort to make my life easier for DIY oil changes, considering running the same oil in my 100 and 200. Moderate climate (North Carolina), normal use.
Thinking 5w30 for both because my (US spec) 100 calls for the higher viscosity, but just want to ensure I understand the impact on the 200 if I went that route - expect decrease in gas mileage and harder cold start if/when temps are cold here?
Thanks
Thanks
So when you buy oil for your changes its a lot of effort to buy different oil for your trucks?
Thanks
It's simple: Use what Toyota specs for the 100 in the 100 and use what Toyota specs for the 200 in the 200.
HTH
Fair point!
HTH
Thank you. If it ain’t broke...
OneI said it before, one stop shop, a few clicks and you've got an oil change on the way
Oil and Filter Change for Toyota, Lexus, and Scion | eBay
Thanks @TonyP! That’s a great resource.
