What kind of gear oil?
SoCal
What kind of gear oil should I run in my diffs? 4:11 gears, no lockers, no posi, just standard gears. FJ62 with auto trans and 33" tires. I was looking at some synthetics, should I run 90w or something else?
cruiser_guy
Wherever the truck stops!!
80w-90 hypoid gear oil will work. Synthetics will provide better lubrication but will also leak out of questionable seals. If you've never done the seals stick with regular oil, if you've done the seals recently go with synthetic.
SoCal
by questionable seals are you refering to the diff gaskets, or the inner axle seals? or both?
Emerald City
when in doubt - dino. sucks to lose $ synthetic to a leak.
there was a good thread on this just the other day - try a quick search.
rob
