What jack and stands to procure?
Brooklyn, NY
Thinking about a trip to Harbor Freight soon and was wondering if the collective knowledge of this group could point me towards the best bang for my buck floor jack and stands that would work with the LC100? I am not married to any specific retailer or brand but I want something safe and budget friendly.
Also curious for suggestions..
Thinking about a trip to Harbor Freight soon and was wondering if the collective knowledge of this group could point me towards the best bang for my buck floor jack and stands that would work with the LC100? I am not married to any specific retailer or brand, but I want something safe and budget friendly.
Any thoughts on grease guns are also very welcome. I am partial to Red/Milwaukee but I would live to hear any opinions.
I have the 3-ton low profile rapid pump from HF as well, been a year and no leaks, works great. Look up your local fb marketplace /offer up for good deals on 6-ton jack stands that’s where I got mine saved more than half of msrp in HF.
I recently picked up the HF Badlands jack as well. My impressions so far is very good. Sturdy, well built and meets the lift and capacity requirement of the 100. On the downside, it is heavier/larger than my 3 other floor jacks. I don't know how long the wheels will last.
Spend the money on US Jack stands... The 100 series and any 4wd vehicle have to get pretty high to easily work on them, I'm not trusting my life on a cheap jack stand. Many things from HF are fine, but I've had enough stuff break (including a jack) to not trust their jackstands no matter what the reviews say. All it takes is a bad QC and your life changes significantly.
How much is heavier? i roll around the 3ton lo profile in my garage and she's a chonker. I imagine the wheels help until you need to pick it up.
I believe 70 lbs. It is supposed to be somewhat portable for like a race truck. I would not be able to accommodate it on my travels.
I'd get stands with a safety pin, braces across the legs, and get them in a size 4x bigger than the planned-for load. (and remember the advertised capacity is almost always for the pair, not for each jack). I use 12 tons stands for my 80. Then always put wheels or a stack of wood under the truck anyway.
I use HF 3T floor jack for years no issues. For stands, I went with Esco flat tops and also got axle adapters
Would 2 pairs of 6-ton jack stands qualify for the "size 4x bigger than planned-for load"? i.e. 2x6 = 12 tons = 4x3 tons.
I'm planning on buying the 6-ton stands because the 12 ton stands are too big/heavy 😂
Thanks!
I use 2x4 jackstands. Screwed together, plenty tall and last forever.
Instructions here:
^^ I am doing 1 side only with 2 stands, so for an 80 or a 100, that'd be about 3T / 2 = 1.5 T x4 = 6T. And then I'll just double it still cuz I worked too long to be flattened before retirement. Gives me 12T. Obviously if you lift it all, you'd need 4 stands so it's the same safety factor. But the notion of having the truck on 4 stands gives me the creeps, so not for me.
Now, one advantage of the bigger stand is that the base is wider -so more stable for a given height-; and you can get higher too if needed (but then less stable again), so more versatile. And it's good exercise to move them around...
Re: grease gun. I think HF is doing a 'buy the battery and charger get the tool free' deal right now so maybe try their electric grease gun? But if you already have the Milwaukee battery system that may be the simpler choice. I have never used either, I get by fine with a non-electric grease gun.
I have ACDelco 12 ton jack stands and a US General aluminum floor jack. I trust HF for nearly everything, but all of the bottle jacks I have from them have failed and I remember seeing the jack stand failures/recall a few years back. They are likely perfectly fine but for something supporting the cruiser's weight above me for hours on end, I chose to steer clear of their jacks and stands.
IMO the biggest benefit of the 12t stands is the height. Unless you use a lot of wood blocks I imagine many 6t stands could not support a 100 from the frame and keep the tires off the ground at full droop. The 12t height felt proportional to me, only downside is it is not practical for smaller cars if you have others in your family.
Having an adjustable height is very useful. And I don't want it any higher than it needs to be, for stability reasons. So I tend to use the adjustable stands as primary for that reason and then will have lower cribbing or big objects as backup.
(There is a big thread around with many discussions of the HF stand recall, reviews of the new ones, and brand alternates.)
I use the Power Torque Tools 6 Ton Jack Stands from O'Reilly. I think I got them on sale for like $65 for the pair ($88 at the moment). I'm pretty happy with them.
