middle east specs comes oemNice NACA ducts on your skids. Did you add those and were there any benefits?
Soo was I wrong ?Interesting
Part numbers:
51409-60040 and 51409-60090
You are right, the middle east spec ones came from the factory like that.Soo was I wrong ?
A cold beer?125,500mi - spark plugs, air filter and cabin air filter, PCV valve, cleaned throttle body. About to flush radiator fluid. Grease front end and driveshaft. Replace Diff and T case fluids. Am I missing anything?
2A cold beer?
How about atf, power steering fluid, and brake fluid? Just random thoughts125,500mi - spark plugs, air filter and cabin air filter, PCV valve, cleaned throttle body. About to flush radiator fluid. Grease front end and driveshaft. Replace Diff and T case fluids. Am I missing anything?
Brake fluid been changed recently?125,500mi - spark plugs, air filter and cabin air filter, PCV valve, cleaned throttle body. About to flush radiator fluid. Grease front end and driveshaft. Replace Diff and T case fluids. Am I missing anything?
Oh yeah I do need to do the power steering. Thank you. Brakes been done but unfortunately this thing has not had the trans fluid changed before and I just bought it so can’t take that risk! Otherwise it’s maintenance record was pretty solid for an average joe.How about atf, power steering fluid, and brake fluid? Just random thoughts
Inquiring minds want to know!Nice NACA ducts on your skids. Did you add those and were there any benefits?
At only 125K miles, I’m sure there’s no risk in doing a drain and refill of atf.Oh yeah I do need to do the power steering. Thank you. Brakes been done but unfortunately this thing has not had the trans fluid changed before and I just bought it so can’t take that risk! Otherwise it’s maintenance record was pretty solid for an average joe.
I’m afraid to because mechanics also say if it’s over 100k and never been changed, it could cause issues to change it now. Do you have plenty of experience changing trans fluid for first time on vehicles over 100k miles and no issues?At only 125K miles, I’m sure there’s no risk in doing a drain and refill of atf.
No experience. You do you, but if it was my new purchase at that mileage, I would not hesitate at all to start a regular schedule of draining and refilling with a couple quarts of fresh World Service atf every X number of miles depending on use case. There is no way I would consider never changing atf, but I admit my LC sees pretty heavy duty use. And, note I would not do a power flush or use any type of cleaner in my transmission.I’m afraid to because mechanics also say if it’s over 100k and never been changed, it could cause issues to change it now. Do you have plenty of experience changing trans fluid for first time on vehicles over 100k miles and no issues?
Yeah my first thought also. But unfortunately I bought this with 125mi and it was never changed. Check this video out it’s a master Toyota tech. Interesting info whether you’re on perfect maintenance schedule or not.No experience. You do you, but if it was my new purchase at that mileage, I would not hesitate at all to start a regular schedule of draining and refilling with a couple quarts of fresh World Service atf every X number of miles depending on use case. There is no way I would consider never changing atf, but I admit my LC sees pretty heavy duty use. And, note I would not do a power flush or use any type of cleaner in my transmission.
That advice is usually regarding a flush if there’s not a history of transmission services.I’m afraid to because mechanics also say if it’s over 100k and never been changed, it could cause issues to change it now. Do you have plenty of experience changing trans fluid for first time on vehicles over 100k miles and no issues?
