What have you done to your 200 Series this week? (14 Viewers)
Got soapy
swapped off the O.Z./Blizzak winters for the stock HE/Dunlops for the season. Considering Toyo AT3 in 285/65/18 and spacers, but going to ride this way for awhile Since I only had 200 miles or so before I put the winters on last Nov.
missing my E63 wagon I traded on this pig. not missing the rattles though. Need to hit some trails.
Just finished my Front Runner Slimline II rack install with the under mount camp table. More stuff to be added tomorrow but today my shoulders are killing me!
Does one of your table mount "cradles" (the side closer toward the front of the vehicle) touch or rest on the ridges in the roof on yours at all? Mine just barely made contact, so I put some clear PPF and a piece of sticky foam to protect from scratching
Took a page out of Markuson's book and got my phone mount set up. Using the ball from a RAM motorcycle mount kit, some long M6 socket head bolts, plastic spacers, an articulating RAM arm, and my old X-grip from my 4Runner. Just sits above the A/C vent and 95% in line with the A-pillar so no visibility issues. Just need to get an add-a-fuse and put a USB charger in one of the blanks on the left side of the steering wheel and it will be good.
Been running mine in that spot in both the GX and the LC for a while now and it's just about perfect. I run my Garmin inReach Mini on the passenger side grab handle. Thanks for the idea of the USB port directly below it, I am going to have to do that now.
Nice! Did it take on water in the cabin?
Please share some pics, especially of the brackets to the roof and the rear spoiler clearance when the awning is deployed! I'm looking at that awning to replace a Foxwing system...
Will do. Working on the brackets now. It's been a little bit of a challenge with the RTTx mounted directly on backbone w/o a physical roof rack. Should have it all sorted out this weekend.
Lots of good things today on the 2014 LX @ 110,000.
Dot 4 brake fluid flush
Radiator drain/fill - will repeat 2-3 more times in near future to turn as much old fluid over.
Verified my AHC lines were not rubbing against one other on the DS rear.
Greased 4/6 zerks
Fixed damaged HVAC damper with plastic epoxy
Cut out upper portion of radiator plastic to monitor/add coolant etc.
