there is a guy on mud selling fuse boxes with some built in relays that looks pretty nice, other than that I would go with the blue sea, Northerntool.com has a good selection and good prices for inverters, but I have found that the ratings are a little on the optimistic side,, so go big if you can
about the tank, where is that 80? what year is it?, lots of time junk yards puncture the tank upon arrival to drain the gas to use and to keep someone from blowing up in the yard, but I need a wiring section if it is the right year, I see one in augusta, but it has been there since 3/10/10 and they only keep them about 90 days, so it is probably about to go away
if it comes down to this... I have a propane forge and have made something similar to this before, but not for a gas tank, you would not have to cut the tank at all, so if I could not get the angles right you are only out some time for removing the tank and coming down here...
if you think you can weld in a patch,, I can take a piece of 16-18 ga steel, make a negative die out of a wood stump and hammer out a piece to replace the corner... you would have to come to my shop in royston with the tank in hand, so we could get as close to perfect a fit as possible.....and it might be easier to just buy another tank,
I am not sure what thickness steel they used on the tank originally, and I do not think I want to weld on a gas tank,, I have read somewhere you have to wash it out with isopropyl alcohol first and let dry for a few days, but have no experience with that and am not sure what would happen to the strength of the original tank along the welds..
it would probably take a few hours to hammer that out once I have a negative to work the steel into
