What Did You Do with Your 80 This Weekend? (43 Viewers)
I took the front end of my LC off, and the battery tray was taken out to replace the front main seal and oil pump gasket where the oil leak culprit was. And distributor seal replaced another leak area. I flushed the motor because someone mixed red and green. Degreased all the greasy areas. Tomorrow I am putting everything back together then flush everything again and fill the girl up with coolant and she should be good to go. And new hoses for the radiator. Going to replace as many hoses in the engine as I can.
To take the balance wheel off. I didn't bump to take off. I put a 14mm bolt in the area where that rubber flap is. Then I used my hi-lift pole as a cheater bar to break the bolt of the balanced wheel.
...via IH8MUD app
Fitted a new light to my tailgate so when its open at night I can cook/see, BTW it's also portable and rechargeable !!!
This looks great! Is it hard wired for charging?
I re-assembled the interior after I had it a part to have the roof welded up. I also installed a engine oil pan heaters.
Reprinted the old grill. I had a local paint supply store make up the exact color in a spray can. $15.00 upgrade.
What a difference 2 hours makes.
Dad's old girl looks like new now.
Changed the oil again. Made some mounts for steel panels.
Scuffed up my paint in prep for the pending monstaliner job. Also installed my tailgate cutting board.
Moved my ready welder into the trunk.
Installed WeatherTech Floorliners. Mistake!
Cheched fitment and started mounting and wiring.my viair on Phil's mount along with an inverter. An decided to do a custom side panel. So removed the metric sub panel and sub..... Meeting a guy who can work with starboard to see if he can fab a side panel the way. I want it to be next week. Will post pics if so
"Installed" a Cobra WX75ST CB with Wilson Lil' Will antenna. Still need to get it SWR'ed, couldn't get anyone to answer back on multiple radio checks. But the fools out here in Vegas on the CB are running like 5000 watts out of the base stations and they just sit there and try to "squash" each other all day. :eek:
