What did you do with your 60 this weekend? (11 Viewers)
Install blue tooth module into the cabin... ✔!!!
Install Noco Genius Gen2 20 amp 2-bank Waterproof on board battery charger into engine bay front.... ✔!!!
Install Marinco onboard charger inlet on ARB front bumper.... ✔ !!!!
Manu, I need to go trolling on your thread to see this mod.
J
Adjusted rear brakes again, took apart right side and cleaned up bell crank. now drinking beer, scratching my head as to why park brake wont work.
Process of elimination, I would start at the brake lever and work your way back. Checking each section and making it work until you find the issue. Good luck
Sat on the beach and watched the waves. Put on my new spare cover.
Did my first knuckle job, and front brake pads. Overall it went well, and the only thing I broke was 1 of the free wheeling hub cover bolts. 7 ft. lbs of torque isn't very much at all. (My torque wrench only goes down to 20 lbs.) :censor:
Also, having the plastic "brake light turn off pad thingy" break while your bleeding the brakes is really bad timing. I seriously bled them 4 times, starting the master cylinder each time, until I checked Mud, and then looked up from the pedal to find the missing piece. :deadhorse::idea:
Swapped out rear driveshaft u-joints chasing an intermittent highway speed vibration (no change). Briefly gave him a once over, chagrined at plentiful porosity purging precious petroleum products and then took the scenic route home.
Made a radiator mount, some roll protection for it, and got my lines figured out for a dove nose.
I also resealed my gutter seams and drip rails. I'll put together a write up on my process soon.
Interested in reading about your rain gutter re-do...
I’ve took back my 60 from the paint shop. Since it was bare naked, I enjoy the weekend to rebuild the exterior, window and doors, bumper….
I will quietly attack the interior this week.
then the roof rack, then the 255/85 MT, exhaust and muffler ...
Changed the same rear inner axle seal twice.
