Not today per se, but I take delivery of my newly purchased 2003 tomorrow
Couple questions, I can always start a new thread if that makes more sense. First is on the dash. The example I'm buying was maintained at the dealer its whole life, and it received a fresh dash under warranty in 2017. It still looks great with no cracking. I've read some mixed opinions on this- were the warranty replacement dashes any different than the originals? I'm prepared to do my best protecting it with 303 or similar, but I'd love to know if there were any fundamental changes to the dash that might help it hold up over time.
Second, I'd love to be schooled a bit on the AHC and adjustable damping on the shocks. As I understand it, these are entirely separate, correct? Down the line, I'd be interested in a very mild lift and some slightly bigger tires (had 1"ish lift and 265s on my v8 4Runner). I also tow, so I'm attracted to some of the benefits of the AHC. I would assume that one could lift a bit while maintaining the AHC (taller bags?), but there is no way to lift and retain the electronic shock damping. Seems likely that the OEM shocks would not take well to any extension, and the valving isn't going to cycle properly. Open to being corrected on these and I'm excited to join the GX club!
I am lifted 1.25" in the front and 1" in the rear on standard bags and lexus adjustable shocks. I tow as well and really appreciate keep the airbags. I run a .75" spacer on the front strut (and correctly space the front bumpstop), and then just use washers on the height sensors in the rear to make it run higher.
What @Krazykevin said. I have a mild lift with after market dampers with the factory air springs. I scoop up air spring components when others remove for rear coil spring conversions. Self leveling is a major feature to keep IMHO. Even if you do not tow. 1-2 passengers wlll activate leveling.
The sloped driveway is tucking that rear wheel more, but she was squatting before cranking up the engine. Trailer was full of dirt in both photos.
@mcaninch35Super helpful @Timujin and @Krazykevin . You haven't found any reduced performance with the stock shocks? Both of yours look great so I'd be thrilled if its reasonable to lift a bit and keep all the stock features.
Same! You can retain AHC air springs and stock AVS shocks with mild lift.
I ran a 0.75" strut top spacer providing 1.5" lift in front and washer spacers to rear airbag sensor providing 0.5" rear lift for 7.5 years. Daily was fine, auto levelling worked perfectly, with hi and low height adjustments retained (for trailer loading and slow speed crawling respectively).
Here's a gif showing ride low, normal and hi ride heights
I then fit 265x70 17s with a little front rubbing fixed by massaging the fender liner.
Quick side-by-side stock rig on stock all seasons left, mine on front spacer and AT BFG KO2s right
Retaining auto levelling is awesome.
Here is loaded for a 2 week road trip; bikes and racks add like 250ish # hanging off the bumper, let along the camping gear on roof, kitchen, cooler and gear in the back, plus 2 pre-teens.
Its been very functional for daily, long-haul road trips, multi-day camping trips and off road adventures. It even wheels mild-light hard trails and even amazingly while loaded around where I live...
