unconfirmed @Bogan sighting?
What is your rim size? ThanksScored some used Kenda 35x10.5 Tires. My old 33's were fine but you know how that goes...
I feel like the 10.5 is the perfect setup for these trucks.
Nicely done! Stainless is fantastic. Some stainless are food grade, so you can wipe it with windex and put food directly on it. I did the same on my 80, as 2 panels that open, so I can use it for storage of all the kitchen stuff. I tried recovery, but ended up too heavy.Installed my first prototype of a stainless inner panel on my 75 tailgate. Super happy how this came out. Looks sand and makes for a nice woking surface on the back of the truck. We will be putting these up on our website soon.
Nice looking LJ; a little crusty underneath.Started the teardown for a knuckle rebuild on my buddies 87 BJ73.
He has all new rotors and calipers to install while I’m there. Having a real hard time separating the old rotor from the hub.
Any suggestions? Already took some heat to it. Tried using the old studs/lugnuts to pound on. Also tried screwing the two bolts that go in from the backside in almost all the way and hitting those with a brass drift. Maybe I need to find a press?
Doing the same!! Can I ask how you separated hub and rotor?Got stuck into the knuckle refreshment. Rotors, calipers and studs all getting replaced. For now I'm mostly just taking stock and seeing what parts I should start gathering.
Also cut off the wire rope fairlead rollers for the winch. Adding an offset fairlead from Slee that should work vetter with the ARB bumper.
AC is out. Curious to see how it runs without it. That's if it even starts with all the wiring I removed along with it.
View attachment 4084920View attachment 4084931
