Changed plugs on my DD 2005 Saab 9-5. Was running a touch rough
Yeah, it's a pretty hellish working environment between the fiberglass, resin fumes, and everything...
One of these in cobalt blue metalflake.
Nice - similar to the Meyers Manx?
Yep: Berrien Buggy by Acme - https://berrienbuggy.com/
The owners actually just ran NORRA in a Manx bodied (to qualify for the Manx class), GM Eco-Tec powered, Berrien chassis with a VW bus transmission.
www.facebook.com
Acme Car Company – New Cumberland, PA
acmecarco.com
If you like Type 1's, here's a '56 project car I'm trying to straighten out for a guy.
Air ride suspension, turbo, fuel injection, electronic ignition. Previous owner got into the project but (clearly) had no idea what he was doing. Current owner bought it as an almost finished project. Ummm... No... Previous owner threw enough of it together to make it look "complete but unfinished" - everywhere I look there are issues. Basically tear it all apart, plan it all out (clearly never done), and put it back together so that it actually works...
I love that the buggy still qualifies as a “Manx”
For the type 1 - how does one mess this up? It’s basically a lawnmower engine it seems like it would be tough to mess up… it’s about the only car I can think of that’s less complicated than a 40…
Take a Type I engine, add a turbo, add fuel injection, add electronic ignition - but don't bother to plan or figure any of it out, how each interacts with the others, and so forth... The oil lines aren't attached to the turbo because they'd have to go through the exhaust to do so - and a section of the exhaust is out because it would go through the bumper bracket. Somehow an oil filter has to be stuffed in there.
Instructions say not to put the fuel pressure regulator in the engine compartment because the heat will affect it - yep, it's in the engine compartment. Instructions say not to use teflon tape on the oil lines because it will get into the turbo and destroy it - yep, everything is teflon tape.
He's got two separate wires backfeeding into the fuse panel and blowing fuses. He's got a 40A circuit to run the two compressors for the air ride wired with sections of 14ga wire - with 8ga between them - AND running through a 5A switch that is properly melted...
Need I go on?
Oof. Nope that clarifies.
Quite simply, he bit off more than he could chew. I think he did the bodywork first and then started on the air ride. Other than the wiring on the air ride and leaks in the plumbing, it isn't too terrible up to that point. But then he got the engine from a sandrail, added the fuel injection, changed turbos because the original just wouldn't fit, and then tried to stuff all the parts into a Beetle. I think he realized that he was in over his head, so he sort of gomblycocked (I created that word just to try to describe this situation) everything together to make it look kind of like it was all there and sold it. At least that's my current understanding of things.
Thankfully, it's a Beetle, so the idea of pulling the entire engine, all the wiring, and going through every inch of the air ride plumbing doesn't put me into the fetal position.
Heck, even pulling the body from the chassis isn't a jaw dropping suggestion...
By the way, pretty much any task on a Beetle starts like this...
- Pull engine
