What are you working on? (5 Viewers)
@FamilyCamper Be sure to swap out the oil pressure switch and metal screen while the intake is off and also the knock sensors and the harness. Both can go bad and the intake has to come back off to replace. It is getting there!
@matzell - glad I listened to you and didn't open up the transmission!
After going over wiring inch, by inch, by inch, and every single fuse etc., I moved on to relays and swapped the ignition relay ($7 why not). Not sure how that went bad, but SUCCESS!
At least it turns over - I think all the gas has evaporated in the months it's been gracing my driveway as a statue.
Progress!!
Thank you to family camper for the help today! Since Thursday, Rear bumper and swing arm install, get my power antenna working again, front brake pads, pull and grease front drive shaft, install 1/2 of my not huggers, install new front locker actuator.
Don't forget tighten up front (super loose) sway bar link!! -1 clunk/rattle in the truck lolol. Good times man one step at a time!!
Pulled and replaced the efi relay and ect sensor and went for a 50+ mile drive. No hiccups but hit start stumble was still there. Then I remembered I had an extra fpr in the glove box and swapped that out. I've let it hear up and started it at various times afterwards and so far no stumble.
I think maybe, there's a chance I've possibly fixed my issues. Needs more drive time but I feel good about it.
Oh and I love my gears. I've put about 250 miles on them and have started driving at highway speeds. It takes off better climbs better and holds speed better. I think the mpgs are slightly better and my Speedo is dead nuts which is awesome.
Thanks again Rob and Allen!
Awesome man. Glad they are working out
