I found it last weekend, she did a song and dance and she drove to PA Sat to pick it up. Lets just say she saved thousands on this set up.That’s some expensive quality stuff right there!
Strong work!!High beam switch is fixed! Still need to finish installing my remote winch controller and then put the rope on the winch.
I think you'll like those Kendas. Read a lot of good reviews and almost got them when I got 35s. Looking forward to seeing the performance on the trail. I wonder what will rub!?View attachment 4068108
Got the 35s mounted
Quick check and only a little rub in the front, rear fender area, easy to take care of. Pretty surprisedI think you'll like those Kendas. Read a lot of good reviews and almost got them when I got 35s. Looking forward to seeing the performance on the trail. I wonder what will rub!?
Making it harder for your wife and kids to climb into when you get that 80 and the 200 becomes the new mom mobile?View attachment 4068108
Got the 35s mounted
Oddly enough my wifes favorite vehicle (and would kill me if I sold it) is my 3500 on 38s. Currently trying to convince my wife to drive a 200 for her mom car too, dont blame her though a 500hp Audi is really fun.Making it harder for your wife and kids to climb into when you get that 80 and the 200 becomes the new mom mobile?Sorry, I’m deep down jelly because I’ve been trying for a few years now to convince my wife to make a 200 her next ride but she’s set on getting back into an E-Class
I've got some ideas on how to work on that bent captive nut as I had to deal with the same thing. You'll need a long pry bar and large hammer.... not sure but may be able to come Sunday I will message you.Spent the past few evenings working on my 4x4labs rear bumper build. Making progress but definitely going slow. So far I have gotten the factory parts removed, crossmember cut out and ground smooth, frame cut back, and sides bolted on. I am busy all day tomorrow but hoping to get the rest of the bumper tacked together Sunday afternoon. If any club members are free and are willing to lend a hand, shoot me a message.
Only issue I currently have is with the captive bolts inside the frame. The bracket that holds the two in the rear has rusted away. Must be some cheap metal because there is not a speck of rust on the frame itself. The passenger side broke free and I was able to reach in the frame and get it to line up. Hopefully I can get the welder in there and tack the nuts back in place. The drivers side bracket is bent and making it impossible to get the last bolt to thread. Spent a good hour messing with it but no luck.
View attachment 4069324View attachment 4069325View attachment 4069326View attachment 4069327
The factory setup is actually a set of two nuts welded on a bracket that was welded to the outside wall of the frame. That part is still decent metal. It’s the thin gauge steel they used to weld to outside wall of inside of frame that is just bent and making it difficult to line both nuts up. Might need to just break the weld free with a pry bar and hammer, straighten bracket, and place in by hand. Not to worried. Plenty of options to fix, just one of those things that adds extra hours to a project.If you can weld the nut to a piece of flat stock, you could place it in place and start the bolt. When you go to tighten it, the flat stock will catch the inside of the frame and lock it into position. Think of it as a lolli pop stick with the nut on the end instead of candy.. You could also use a random bolt, butt welded to the side of the nut as well. Just something that will lock in place. Make it long enough to hold so you can start the bolt.
It is hard to explain this to customers sometimes when working on older vehicles. Good luck.The factory setup is actually a set of two nuts welded on a bracket that was welded to the outside wall of the frame. That part is still decent metal. It’s the thin gauge steel they used to weld to outside wall of inside of frame that is just bent and making it difficult to line both nuts up. Might need to just break the weld free with a pry bar and hammer, straighten bracket, and place in by hand. Not to worried. Plenty of options to fix, just one of those things that adds extra hours to a project.
I saw Curly Dave’s handiwork at the same area this past weekend and need something similar. I don’t care how much the necessary cutting affects the overall look because most will be covered on the sides with a new bumper. As long as it stops the cancer and keeps me going! I’ve regretted for years not learning basic welding skills and this is a perfect example of why!Build - TRDdrew's build: let me introduce Waffles - https://forum.ih8mud.com/threads/trddrews-build-let-me-introduce-waffles.1315659/post-16142758
I need to do something similar. This is going to be my inspiration. That said Andrew is a paint and body guy so it won’t turn out like this
