1HDT with 105,000km. Went in for a transmission rebuild and coming out needing a engine rebuild FML.
A little back story. About 6 months ago I had my ACSD sheer off inside the pump and do some significant damage to the pump and a few injectors. It was only running on a few cylinders. Skipping, smoking and shutting off all the way to the injection shop. After it was buttoned back up with rebuilt pump and injectors the truck has ran amazing for about 5,000km.
NEW ISSUE: my clutch hydraulics gave out. Towed it to shop to have a new clutch installed and the H151 rebuilt with new synchros, new slave and rebuilt master cylinder. Before I towed it to the shop I noticed the crank pulley wobbling just a very small amount. Figured it was the harmonic balancer going bad so ordered a new one. Go to pickup the truck after it’s trans overhaul and hear a noticeably loud knocking coming from “somewhere”. The shop thought it was the new HD clutch. Take it for a quick spin still has good power and runs fine, no smoke, overall not bad other than the unknown chatter. Popped the hood to see that the crank pulley was noticeably wobbling even more and the sound appears to be coming from the balancer and oil pan area. Once the harmonic balancer was pulled it was very apparent the crankshaft has an abundant amount of end float and up and down movement just by hand.
Obviously so far I don’t know if the crank has snapped or if the thrust and main bearings are shot. The BEBs were done on the truck at 97,000km. Plans are to pull the engine and rebuild and replace whatever is necessary.
What I’m really here for and hoping some of the experts here can weigh in on is why is this somewhat a common issue on these diesels. I’m worried that even after a complete engine overhaul. This same scenario will play out again and never know exactly why. My only best guess some damage was done when the injection pump took a poop.
Thanks for any help and insight.
