Looks good,
There are a couple of ways to prime... by far the best method (which I use) is to get an external oil pump from say an old chev v8, make up an adapter to screw on to the oil filter thread so you can pump oil directly into the engine...
Have someone spin the chev oil pump with a drill to build pressure, while they are doing that start cranking the engine over until oil starts squirting out of the oil filter output hole. That way you know the oil pump is working and providing oil meanwhile the chev pump has protected the motor.
If you crank for like 30 seconds and no oil comes out it means you have an issue with the main pump.
If that doesn’t make sense let me know and I can post some pictures up. But for the relatively low cost (external pump, fittings hoses etc might be $100) but it’s the only way to absolutely protect the engine during first crank.
