Water Pump Replacement (1 Viewer)
Great idea to stick the bolts in a diagram on the box. :idea:
Thanks for posting this. I'm hoping to get my first one for free before the warranty ends at 100k. ;)
Adding to the water pump removal thread. Pretty straight forward job. Just some hard to reach clamps/nuts. There is one bolt that is hard to reach/take off and even harder to put back without removing the compressor pulley. Not sure people that have done this job remove pulley or just struggle thru the very tight space. In order to get to the pump you have to remove a whole bunch on rubber hoses and metal bypass hoses. One such metal hose has 3 bolts mounting it to the engine block. One of the three is the one I am talking bout. Here is a pic of the bolt and the pulley/clutch you remove from the compressor to make the removal and install of bolt a breeze. It is a 10mm bolt that holds on the pulley and then there is special different looking snap ring, that's it.. Here is the pics:
Whoops, here's the pics
FWIW, my water pump was not leaking and bearing felt nice and smooth at nearly 100k, but decided to replace since I was slapping on a new radiator and thermostat...
I'm collecting parts to do this job. Thanks for the heads up. Wondering if it wouldn't be easier to undo the whole compressor? I haven't worked on this motor yet, but usually there's 2-3 large bolts and/or studs and it moves rather easily?
Not sure how to or how long it would take to remove the whole compressor, but removing the 10mm bolt and the snap ring took all of approx 2 mins... Just make sure to position the snap ring pliers directly to the 2 points on the snap ring.. Be careful not to lose a very small 1/4" washer that will slide out behind the pulley...
Great info,that is my next project.My water pump is fine and radiator is not cracked but I will change it anyway.
Feedback and a question:
  • Removing the bolt behind the compressor pulley is not required to complete the job. You can get a open-ended wrench in there and back the bolt out about 2/3 of the way without difficulty. With the two upper bolts for the pipes removed and the upper hoses disconnected you have plenty of wiggle room to get things done. The lower fan bracket bolts require a sequence to get them in but its not a problem. To be clear you do need to flex the tubes a small amount and should be careful that you don't crimp them. Those with good mechanical sensitivity will know the difference between spring and bending. If you're not replacing the fan bracket then it doesn't even require that much movement.
  • I did try to follow the above and remove the pulley. At least with my snap ring pliers I couldn't get a purchase on the eyes without coming at them straight on which can only be done with the radiator out. Removing the radiator makes the whole job easier, though you do lose about 3 tablespoons of ATF. Getting the 10mm bolt is fairly easy and requires a strap wench to hold the outer clutch wheel. And it should be underscored to NOT LOSE the washer that lives inside the clutch splines! This is critical to space the clutch from the free spooling pulley. I couldn't, however, get the pulley to come off even with the snap ring removed. Is there a trick? Everything else on my truck is very much rust free so I don't think it was corrosion. The frustrating part is that I think it did move outboard a few thousandths because when the clutch was reinstalled it completely engaged and did not allow the pulley to spin! After spending a good deal of time troubleshooting I found a combination of washers in spare parts bin that added about 0.5 mm to the spacing and the A/C now engages as expected. I'm guessing that my fiddling dislodged some crud that prevented the pulley from seating back all the way. Anyway, I'm just curious as to what the trick was to get it to come off?
I did this job over the weekend, along with the radiator, thermostat, fan bracket and main water hoses.
The tips in this thread were very helpful to anticipate potential sticking points, so big thanks for those that contributed! I ended up just loosening that bolt next to the A/C compressor and had plenty of wiggle to get the fan bracket off. Actually, where I needed the most wiggle was in separating the rubber hoses from the metal lines. The hoses are short so you don't have much to grab onto, and I didn't buy new ones so I didn't want to damage them.
I started to try to remove my compressor pulley today and got clutch part off and found two little washers in the splined hole. Then I discovered the snap ring and had to stop because I didn’t have a snap ring pliers. Can you clarify what you are saying above about the combination of washers you used? Did you add an additional washer in the splined hole to hold the clutch out a little further? Just wondering if that’s what happened sometime before on my compressor pulley. I’ve never had it apart.
Good thread guys. Does anyone know the part number for the small hose that connects to the thermostat housing? It's stamped K120413 but I can't find anything online. It's the hose he references at 4:20 in this very informative video: Youtube Video . It was a tight space and I tried removing it before watching the video and tore the dang thing.
Pics from my 2013 replacement to show the hose. Doing the belt, upper and lower radiator hoses, tensioner pully, water pump and pully, and thermostat.
Well, think I found it. Looks like Toyota 99556-20200 heater hose. I suppose I just have to cut it to length.
That is the part number I show in my diagrams.
Bringing this one to the top. Doing water pump on wife's LX570 and making sure I have all the parts.
Here is what i have so far,
16100-09491 water pump assembly
16031-0S010 inlet sub-assembly with thermostat
90916-A2033 serpentine belt
16620-0S012 drive belt tensioner
16603-38012 drive belt pulley
I'll need coolant, but other than that am I missing anything. Plan to knock this out next weekend if I can get all the parts here.
@Mogwai
@Bama4door does this list look complete?
Thanks in advance
@Mogwai
Thanks in advance
I did mine almost a year ago. I changed the water pump only and left everything else as is. As for needing anything else for the install, one of the YouTube install videos I saw recommended silicone grease on the thermostat housing gasket to help hold it in place.
@Mogwai
Thanks in advance
I think you're missing the fan bracket, I posted a table recently with everything needed plus the two heater hose assemblies that have the Heater Ts.
Link to table?
Link to table?
ItemPN
Radiator16400-50384
Upper hose16571-38080
Lower hose16572-38131
Thermostat16031-0S010
Water pump16100-09491
Serp tensioner16620-0S012
Idler pulley16603-38012
Water P Gasket (Apparently not needed... WP comes with a gasket...)16271-38020 (Comes w WP)
Serp belt90916-A2033
Thermostat housing gasketComes with T-Stat
Fan support bearing16380-0S010
And these are the two heater hose assemblies-
87209-60C01
87209-60C12
Back to top, due to an unfortunate act of stupidity I'm going to be doing a lot more work. Does anyone know if the fan, fan clutch and shroud are shared between the LX and LC? Asking for a friend...
