With my supercharged engine essentially rebuilt (even if the tranny isn't bolted up yet) I'm ordering materials to build my Water-Air intercooler.
The base of the project is (3) Laminova 39.5 x 392mm cores I sourced off ebay:
Tonight I ordered all the 6061/6063 aluminum plate/flat/tube. Used SpeedyMetals.com since I've had good experience with them in the past.
I'm now researching parts for the heat exchanger, tubing, etc. and found a place called FrozenBoost.com. Looks like a good outfit, but I've never used them and was hoping someone on the forum has had past experience - anyone??
They have two parts (that form a functional unit) that I'm particularly interested in. The first is a set of pipe ends I'd use to connect the intercooler to the intake manifold:
the second is the clamp that holds them together:
My vision is to mount the intercooler over the head, between the supercharger outlet and the intake chamber. These give me a quick release on the intake end to remove it for completely open access [unfortunately I think I'm stuck with bolts on the other end]. Does that sound reasonable? I know it's not terribly clear, but will hopefully make sense as I add build photos.
Be advised, this project is NOT going to move quickly. I still need to buy a TIG welder, but just learned tonight I owe even more $$ to the IRS. I'll update as I move along, I'm just terribly busy & underfunded.
Thanks for the advice,
Jon
Jon
