Builds Warhorse-LS3 C&C & more
NCFJ
Supporting Vendor
Chesnee, SC
Warhorse as he arrived.
This truck will be getting Lizard Skin inside and out, sound deadening and thermal. Frame and suspension will be taken to bare metal and painted, axles rebuilt, new brakes and a laundry list of other work as well.
A little surgery was required. Removing enough frame to make the wheelbase work under the 60 was fun. I sleeved it with a box made from 1/4" steel, 18" long. Seam was left open enough for the welds to penetrate well into the inner sleeve. 46 rosette welds total. I do not think it will move :)
It all came together with very little effort
Sweet.
I got it to ride height and correct placement on the frame. Amazing the amount of work/time to get to this point. Lots of variables to contend with.
WOW! The hits just keep on coming!
Subscribed..............again.
Uh-huh
All but the rearmost two body mounts are tacked in. The frame rails have to be raised a bit in the rear to accommodate them. A whole lot of measuring, measuring again and looking at the truck from every angle.
More frame cutting fun!
The frame has to raise up to the bottom of the rule, a bit over two inches, in order for the 4 rear body mounts to work and be OK for bumper height. I only wanted to make one cut on the frame and not lose any length or add plate to it. So if I cut in just the right spot I can flip it over and weld it right up the same seam and gain the height I need
A little bit of math and a template to prove concept to myself, bingo!!
Point of no return?
Did I mention that due to the outer C of the frame box being larger than the inner C, I need to flip the frame sections side to side in order for the outer C to remain the larger section?
Even a blind squirrel finds a nut once in a while.
I like it without the upper triangle filled in. Two 3" x 6" 1/4" plate reinforcement on the inside, beveled seam spaced so weld goes through to plates, 18 rosette welds. Don't think its going anywhere
