Yes. That's what I refered to as "in time" but I guess it's called phase.In phase.
Out of phase.
Out of phase.
A "driveline shop" that installs castor bushings does not specialize in Driveline's only, which raises and eyebrow right off the bat.So a little update here....I went to a reputable Driveline shop and they stated even before looking at the vehicle that they regularly install the castor correction bushings on FJ80's and that should fix the vibration sound. Mine apparently were not installed correctly so they redid the bushings based on a "template" they frequently use. They did find the rear driveshaft ujoints out of spec and replaced those. I drove the vehicle home.....same vibration sound although not as loud. Since then (it's been a couple of weeks now) the vibration has gradually diminished to the point I don't notice it or hear it.
. It just so happens that an 80 series lifted a solid 3 to 4 inches and with proper castor correction, is automatically configured to run a D.C. Shaft in the front. Thanks those Toyoda engineers for thinking ahead.![]()
That's got to be one of the oddest statements I have read on this board. Take a look at Slee's 4" complete kit. What you are saying defies the general concensus.Your 80 must have been built in a different factory to mine.
If you have correct caster, your pinion angle is not going to be correct for a DC shaft
I appreciate you explaining the basics, which I have gone through on several different vehicles in 30 years of wheeling.maybe, but what you are saying doesn't work physically, regardless of the consensus.
where does your consensus come from? it could be argued that there is also a consensus that DC shaft is far from ideal and is not without its own problems, yet DC shaft persists as a "solution"
if you lift your truck the radius arms rotate downward, as the diff housing is "fixed" in relation to the radius arms, you end up with the diff pinion pointing upward toward the transfer (more so than in standard form), and the king pin is angled forward at the top so you lose the built in caster
caster correction (plates, or bushes, or washer mod) changes the diff housing's "fixed" position at the radius arms, and rotates the front diff housing downward at the rear. the whole purpose of caster correction is to rotate the diff housing so it is as close as possible to its standard orientation in relation to the ground and chassis, and so the king pin angle is back within factory spec.
you cannot physically add caster correction with caster plates, caster bushes, or custom radius arms, and have the pinion pointing/angled to the transfer case. pinion angle and king pin angle are both an integral part of the front diff housing, you cannot change one without changing the other (without use of a grinder, or offset king pin bearings)
in stock trim, the transfer and diff pinion should both be parallel to each other (within a couple of degrees), lift the truck without caster correction, you change the front pinion angle. correct your caster so that it is within spec, and your diff pinion will again be parallel to the transfer pinion.
A DC shaft will vibrate in a situation where your diff and transfer pinion are parallel, they also tend to chew Uni joints more quickly
there's a great explanation of all this on Pirate in the Billavista tech pages (not sure I have the name right here)
I have previously used caster plates, and also caster correction bushes. none of these have left a pinion angle that is correct with a DC shaft.
I've also done a knuckle cut and rotate to correct caster which has a whole new set of problems
I have good mates that have gone down the DC shaft route, and after several failures, have gone back to standard shafts
