Vibration from front and rear 2005 LX470
United Arab Emirates
Hi I bought a used 2005 LX470. It was not in a good shape. So, I performed the following works on it:
Front:
New Axles and hub flanges
New globes for AHC
New differential (yeah it was noisy and leaking) along with its bushing
Tires Balancing job done recently
Drive shaft lubricated with grease
Rear:
New axles seals (it was leaking)
New rear bearings
Front vibration:
The front steering start slight vibration at 100 kmph and then it increases with speed. Its not worse but I still feels it.
Rear Vibration:
The Vibration looks like coming from the rear differential or drive shaft. it starts above 120 kmph and suddenly become worse at 140 kmph.
One thing I observe that the low range gear lever also vibrates even at very low speed. Not sure if this is normal or there is some issue.
Can someone please help me to resolve the above issues.
Pics help. Post some.
1) Recommend an alignment
2) Verify ujoints on drive shafts are good, greasing is not enough. Remove each drive shaft and check both ends for play
3) verify drive shafts are balanced
Accident history ?
remove 1 driveshaft at a time, and road test. You can drive aroudn with your center diff locked with one of the driveshafts removed.
