VI: Buy/Sell/Trade, In Search Of (12 Viewers)
Looking for a 2 or 3 hp electric motor for my latest toy... to replace the 3 phase 1.5hp motor on this unit :D
Looks like the one that was just on "usedvic". That's a good unit, good score!
It was on usedvic for 5 months. Under all the dust it was in very good shape.
I'm pretty stoked to have a real compressor... After years of making due with compressors that wouldn't crack a lugnut. It's a sad state when my onboard air was a stronger setup than my "shop" compressor.
I've got impacts, ratchet, air chisels, a pnumatic drill, mini-die grinder, dual-action sander, & paint guns... all sitting in a drawer.
Anyone have some 60 series hard lines for the rear heater? Bypassed mine a couple years ago because they're r.a.f.
Otherwise I'll just run some rubber lines back there.
I don’t think I saved the set from that truck I cut down. But I can bring the truck over if you want to measure up a template for a set
Nah it's ok. The s***ty ones are still in mine , but I'll probably just run some hose down there.
Pretty low priority , thought I might install a coolant heater at the same time if I get motivated to that degree.
Hey Ryan, we built a set for a truck years ago out of copper and it worked out...
Cathy was working in the portable MRI...Friday..what a waste of tax payers money that is...
Yep. It's a piece of s***. Viha doesn't really have good ideas. Only bad ones that they continue to throw money at until they're too expensive and embarrassing to abandon.
Did the same for my 40 1/2 inch copper pipe with rubber hose slid over for an insulator, Good for life!
Yep, I've considered copper.
But when we're talking about a heater I'll probably never even turn on, there's a very limited amount of work I'm prepared to do...:lol:
That's pretty fancy, why not just go with a hawse? Mind you, the price is good on that/
Cruiserpilot (et al), I would be open to a Hawse (steel, not aluminum as I'm keeping my steel cable) if anyone has one.
I have a steel hawse. Somewhere, it’s yours now. Home in Dec
Looking for a 24volt external regulator for Hj61
That's the original part, will also accept 27700-57080 aftermarket avr-512 or re214. Used on most import 24volt system trucks.
