Very Special FJ60 headlights woes
Elko NV
Here is one for all the sparkies!
The situation is I currently have no low beams on either side (0 volts at connector), and high beams rights side only (~5 volts left, ~11 volts right). When high beams are selected the high beam indicator does not turn on. Combination switch contacts are cleaned and linked correctly. Where should I look next from here?
Thanks!
Have the lights been upgraded or are they stock ? Are you using aftermarket relays and or wiring ?
Stock wiring, running LED headlights. No problem when installed, ran perfectly for last 4 months.
