Is there any reason I cannot use tie rod ends on the relay rod aka Center Link? I am getting tired of replacing these spring loaded joints that seem to wear out very quickly.
Frank
Frank
Is there a difference in ration between the 60 and the 80 box? One of my complaints about my truck is how slow it is to turn, and I think it was designed this way as self preservation if you will...I am not happy with the steering or the whole front geometry of my set up, I have old man emu 2.5" with longer shackles and it could be so much better....My truck does not eat steering boxes, it eats the spring loaded joints.
My truck is lifted mildly. I have an FJ80 steering box and Fj80's, along with well, just about every other vehicle in existence that uses a steering box, do not have or require these pesky spring loaded joints. I would really like to get rid of them forever hence my wondering if I can replace them with the tie rod ends that use the typical ball joint style of joint.
Frank
It sounds like I need to pave the way here. Can anyone think of a reason I cannot use an FJ80 Pitman arm? I think it drops a bit farther but that could help things here with the lift and would take care of one end. If I do that than I believe I just need to get a bushing to resize that tie rod hole?
Frank
