I was wheeling this 4th and blowed the front slip yoke apart and was wondering if there is any upgraded chromoly slips that anyone is running or know of.
x2...was it fully extended when it popped ..... do you have a lift on the truck ,,, you could just need a longer slip so at full drop there is still plenty of splines still meshing ...... just my 2 cents
It was not at full drop it was compressed actually I was pushing my way up on a rock I did not blow out the splines I split the ears as in the picture
was it fully extended when it popped ..... do you have a lift on the truck ,,, you could just need a longer slip so at full drop there is still plenty of slines still meshing ...... jusy my 2 cents
To much grease did not cause it and there was not to much grease in it. I guess no one has a upgrades for this or not that I can find. I called high angle drive line and they wanted to build me some joint with adapters to a 1310 and all this junk and I told him the joint did not break that I was needing a upgraded yoke.
