Unobtainium (8 Viewers)
Proportioning Valve for BJ42 which bolts under the brake master cylinder.
.. As are replacement wiper motors for '75-'77 and '78 to '84, and OEM style power steering pump.
If you happen to need an OEM power steering pump to get this going - I have a leaky one sitting on the shelf. Just FYI.
Thanks. I got my own leaky one :)
The OEMs all end up leaking, so there is room for improvement. The plan is to make it with highly robust HNBR seals.
@Racer65 After seeing those fenders... If you could get a run of Hoods made (75+) that would be the bees knees!!!
@Racer65 Can you source these?
63381-90800 RH
63382-90800 LH
Picture is of the LH garnish.
Years and 4X series they were used on? A 84 troopy had these as well as the trim piece that ran around the back that covers the seam between the top and sides. This was a late model troopy. The hole in garnish is for a pin. Would be interested in those. Besides garnish a few.of these pins held the trim in the corners.
According to the parts catalog they where used on 40 series troopies bj45 hj47 fj45 1980-1984(1985).
The trim has partnumber 63393-90801.
The pins, you need 7, are partnumber 90467-07027.
Any thoughts on selling just a boot for a Toyota brake booster? It seems like these boots fail long before the booster does...
I know your producing the full booster but it seems like the boots alone are unobtanium.
I have a later (wider) booster from a later model Toyota (FJ60? Forerunner?) but I'm not sure how much these changed...
I think you'll find you need more than just the boot. There is material inside the boot that is likely gone as well.
Well, I floated your crazy request...and looks like it can be arranged, for a price.
I saw a post once by Johnathan Ward that said he would buy 100 40 hoods if he could find them. That and I bet @beno could sell all you could make him to FJ co.
It would be a grand slam move.
  • Back
