- Joined
- May 19, 2013
- Threads
- 5
- Messages
- 392
- Location
- Simpsonville, SC
- Website
- www.scthrivin123.le-vel.com
All is well with my nutsCheck your hub nuts too?
All is well with my nuts.
OUT or IN? Mine went out while I was at Sand Hollow and couldn't figure out how it could possibly do that. Nothing was bent or loose.I got an alignment in the gx... Adjusted the coil overs.... Toe is out again. Lol
I am assuming by "hub nuts" you are referring to the spindle nuts that preload the tapered roller bearings. I recently repacked the front bearing and set preload when I replaced my brake pads. I'm anal about checking and tightening fasteners on the truck since finding my lower knuckle studs/nuts were loose at one time. There is absolutely no play in my front axle and steering components. Steering is light, floaty, and wandering. Tire wear is normal across the tread the tire, nothing uneven.All 4 of them???
Adjusted down so I am assuming it went outOUT or IN? Mine went out while I was at Sand Hollow and couldn't figure out how it could possibly do that. Nothing was bent or loose.
^^ B O A T ^^
B- Break
O- Out
A - Another
T - Thousand $$$$
Posts like this make me remember why I don't have a boat anymore.
For those with pressurized fuel tanks, this is the canister I used on mine. I noticed the pressure the first time I filled up after buying it and thought it was strange. In researching it, found that it can/will lead to ruptured gas tanks and is the fault of a clogged vapor system. Nobody seems to know for sure why, ethanol seems the most common blame, but a canister swap seems to resolve it. The FSM lists a process for cleaning the canister using low pressure air. I did this several times and had no improvement.
Vapor Canister AIRTEX 4B1004
The OEM canister has a 3rd vent hose underneath that runs down to the frame. This one vents from the bottom and there is no hose, so I plugged the frame hose and left it in place for now. You will need to use a longer bolt for the top part of the clamp, and leave the bottom clamp off.
You can also cut open your OEM canister (don't forget there is fuel vapor in there) and repack with activated charcoal for aquariums. You will need to reseal it afterward and the common practice is JB Weld. Some are also removing the check valves.
@ceby @IcutYourCruiser
This just on 80 series?Adding this to my long list of maintenance to do.
^^^I missed that convo.
